Author Topic: Do cherry keycaps fit on Filco?  (Read 4958 times)
Offline Telstar
« on: Tue, 25 October 2011, 12:58:05 »
In particular the double shots from G80-11908 to a Filco Majestouch 2.
Tnx in advance.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Tue, 25 October 2011, 14:00:24 »
Any that are the same size will fit. You will find that many of them will not. If you are after a complete doubleshot set there are better options that will get you much closer. See this thread for example.
Offline Telstar
« Reply #2 on: Tue, 25 October 2011, 14:25:24 »
I'm asking because I dont know.
i'm after an ITALIAN complete doubleshot.
« Reply #3 on: Tue, 25 October 2011, 14:41:55 »
I see. If you want Italian, the g80-11908HRMIT on ebay would be a very good start since Italian doubleshots are more uncommon. All of the single unit letters, numbers, puncuation, backspace, tab and arrows will fit correctly. If you have an ISO filco, you can also use the enter and the left shift. Nothing else will fit properly in its intended location.
I have one myself, it is a nice board too.
« Last Edit: Tue, 25 October 2011, 14:44:36 by lysol »
Offline Telstar
« Reply #4 on: Tue, 25 October 2011, 18:38:10 »
Yep, that's the one. I have to find a reshipper located in the US since they dont sell overseas.
This is the Filco i wtb:
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=813
