Author Topic: $10 for one of these here in Brazil... is it worthy?  (Read 2637 times)
Offline dicho
« on: Wed, 26 October 2011, 20:55:43 »
Hey guys, I am tempted to try an item equal to this:
http://www.ebay.com/itm/FKD46AK208-AT-Keyboard-MADE-IN-TAIWAN-/150635786996#ht_682wt_1039
it is about $10 (15 BRL) here in Brazil, but I have no idea of which switch type is this.
I appreciate if you can help me to find out what the frak is this switch (or if it is just an ordinary membrane/dome disguised as some cruciform temptation).
Best regards!
Offline Oqsy
« Reply #1 on: Wed, 26 October 2011, 22:36:51 »
My brain says check the wiki, but my heart says make something up and pretend like it was a joke if dead wrong. Decisions.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline bloodygood
« Reply #2 on: Wed, 26 October 2011, 23:13:49 »
I was looking up the model number earlier and remember reading something that made me believe it was a rubber dome keyboard, I can't be certain as it seemed like they were talking on broken english. But I would check with a seller if you can type on it first, that is the best way to know for sure.
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
Offline dicho
« Reply #3 on: Wed, 26 October 2011, 23:22:00 »
Quote from: Oqsy;440241
I have been looking into the wiki(s) for hours so far, could not find any reference.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 26 October 2011, 23:49:50 »
Pretty sure its some rubber dome, probably Seijin OEM. One of the easier ways to tell is the top plate and the 'switch' housing are the same piece.
Offline dicho
« Reply #5 on: Wed, 26 October 2011, 23:55:07 »
Quote from: lysol;440278
Thanks. Won't buy it unless some collector wants me to source it.
