Author Topic: Are these double shot?  (Read 4331 times)
Offline Retox
« on: Wed, 26 October 2011, 22:34:44 »
I know that there is some confusion about cherry model numbers, but this MY switch board has doubleshots that are compatible with mx switches right?
http://www.ebay.com/itm/CHERRY-G81-1822HQMUS-PS2-BLACK-KEYBOARD-/230618121302?pt=PCA_Mice_Trackballs&hash=item35b1e94456#ht_500wt_1180
QFR with ergo clears
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Wed, 26 October 2011, 22:50:48 »
Sure is. Pretty good price on NIB too.
Offline nolliepoper
« Reply #2 on: Wed, 26 October 2011, 22:53:06 »
Just be careful the bottom row sizes and the stepped Capslock.
Source: http://www.keyboardlover.com/keycaps.php
Scroll down to: Cherry Corp Doubleshots - Scrounging guide
Filco MJ2 TKL (Brown)
¯\\_(ツ)_/¯
« Reply #3 on: Wed, 26 October 2011, 22:56:26 »
Actually the biggest non obvious problem with that model is the navcluster, witch is all r4 profile so it will look really funny on a board with the nav cluster in the usual place.
Offline Retox
« Reply #4 on: Wed, 26 October 2011, 23:10:24 »
I'm planning on putting them on a g80-1865 with ergo clears. It's basically an identical layout so I don't think I'll have any problems
« Reply #5 on: Wed, 26 October 2011, 23:15:00 »
It is identical, so you would be all set in that case. The body should be interchangeable as well I think so you can have one spare if recoloring goes terribly wrong.
