Author Topic: IBM Model M Red Esc Key Cap  (Read 4543 times)
Offline popol
  • Trade Count: (0)
« on: Thu, 27 October 2011, 04:31:55 »
Hi,
I would like to get a red esc for my IBM model M (or at least the 2nd layer).
Don't know where to find that kind of colored modifier keycaps.
Thanks in advance for your help :)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
  • Trade Count: (0)
« Reply #1 on: Thu, 27 October 2011, 07:54:27 »
Unicomp sells colored M-compatible keycaps:
http://pckeyboards.stores.yahoo.net/mibuandpa.html
They don't have every key in every color but I'm sure they have red Escape.
Offline popol
  • Trade Count: (0)
« Reply #2 on: Thu, 27 October 2011, 08:47:27 »
Quote from: hashbaz;440409
thanks.
My model M is a model with the keycaps in 2 parts. Are the unicomp compatible?
Offline czarek
  • Trade Count: (0)
  • Keep the momentum going!
    • FalbaTech
« Reply #3 on: Thu, 27 October 2011, 09:01:50 »
They do both types.
Offline bootstrap
  • Trade Count: (0)
    • epiguru.com - My Personal Website
« Reply #4 on: Fri, 28 October 2011, 03:57:46 »
@popol - Not sure if you found what you wanted. In case you haven't got a red Esc yet, kinkng might be able to help you. One reason why you might not want to buy from Unicomp is that they require a $10 minimum purchase. That's not a problem for most people.
« Last Edit: Fri, 28 October 2011, 04:44:08 by bootstrap »
The Best WordPress Theme Ever | Kinesis Contoured Model 100 | IBM Model F 1387033 "Space Unsaver" | CH Products DT225 Trackball x 2
