Author Topic: Das S Professional (Blues) for Noppoo Choc Mini (Browns)  (Read 1504 times)
Offline Wallach
  • Trade Count: (0)
« on: Thu, 27 October 2011, 11:22:36 »
As title states, I'm looking to make kind of an odd 'board swap to try out a new layout.
This Das S Professional was purchased from another Geekhacker right around the last week of July so I started using it around the beginning of August. When I received it, it was in pretty much new condition.
It has seen some pretty heavy use in the time I've had it, so the legends are starting to wear a bit on the main cluster. Mostly the heavily used keys, like the home row stuff. Every key still works perfectly though. The casing looks pretty good; there are some faint scratches on the base, and there is one small spot that looks kind of like a pock mark just to the left of the number pad (pics below). That's about it as far as signs of wear.
If you're one of the ones bothered, I think a couple of keys on this board are pingy. W and ; at least. Not so much that I've ever cared in normal use of the 'board, but it's there.
I'm mainly looking to just swap the 'board for a Noppoo Choc Mini w/ browns so long as it is one of the newer revisions. Otherwise I'd probably just sell it for ~$85 plus shipping. CONUS only please.
Pics:
[ Attachment Invalid Or Does Not Exist ] 30093[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 30094[/ATTACH]
« Last Edit: Fri, 28 October 2011, 07:26:30 by Wallach »
