Author Topic: [IC] Nyancat Backspace and row 4 set  (Read 109120 times)
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #100 on: Sun, 30 October 2011, 13:47:58 »
Quote from: Zifle;442276
Not sure if I'm doing this right, but here goes;
I took Hazeluff's image and scaled it down, put it on some caps. Results:
(Attachment Link) 30361[/ATTACH]
(Attachment Link) 30360[/ATTACH]
First one uses the same rainbow cap all the way, the other alternates between two caps, whose both placement of the individual rainbow stripes, and the texture as whole, is alternated.
I believe there could be made a couple of adjustments to make it look better, if you have any suggestions please let me know. You could also edit it yourself, of course ;3
Oh and, make sure you view them in full resolution, or the rainbow fukka's occasionally >.>
I like the first one, but it just needs all the number keys to be the same keycap.
[ Attachment Invalid Or Does Not Exist ] 30369[/ATTACH]
I'd like to have the letters of keys we're replacing to be in the blank area, but that means adding alot of keys to the set (so probably a bad idea).
[ Attachment Invalid Or Does Not Exist ] 30372[/ATTACH]
« Last Edit: Sun, 30 October 2011, 13:56:34 by hazeluff »
Fight For Freedom. Stand with Hong Kongers
Offline tsangan
  • 1000/600
« Reply #101 on: Sun, 30 October 2011, 13:51:05 »
hazeluff: Not feeling it with the lettering definitely takes away from the whole picture in general. Also like you said the cost would be much higher
Keyboardless
Offline Ragnorock
  • Group Buy Guy
« Reply #102 on: Sun, 30 October 2011, 13:56:31 »
Yeah this isn't a group buy for a set of all the keys from ~1234567890-= because that would be much higher in cost. If we don't legend them, then we only have to make 2 or 3 different keys, and its much cheaper.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #103 on: Sun, 30 October 2011, 13:58:09 »
Quote from: tsangan;442311
Quote from: Ragnorock;442313
Yeah, was just throwing it out there (I thought it was a decent idea, excluding the obvious cost problems).
Otherwise, I think the big waves would be best.
Offline tsangan
  • 1000/600
« Reply #104 on: Sun, 30 October 2011, 13:59:30 »
Big wave on white or small wave with stars on blue ;D
I'm so down with either lol
Keyboardless
Offline Zifle
  • Nyaaa
« Reply #105 on: Sun, 30 October 2011, 14:00:57 »
Quote from: hazeluff;442315
I agree with this. However, if we're printing on blue caps, this could work aswell;
[ Attachment Invalid Or Does Not Exist ] 30373[/ATTACH]
I like cats.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #106 on: Sun, 30 October 2011, 14:03:10 »
Quote from: Zifle;442319
(Attachment Link) 30373[/ATTACH]
I vote for this ! (Cept dont think we need a different key for "up" and "down" wave).
Also, damn you beat me to it (was gonna do that right after i saw the last post). GJ tho, it looks amazing = D
Offline tsangan
  • 1000/600
« Reply #107 on: Sun, 30 October 2011, 14:05:56 »
Zifle: looks amazing esp with the 2 different keys for alternating stars and waves ;O
Keyboardless
Offline Ragnorock
  • Group Buy Guy
« Reply #108 on: Sun, 30 October 2011, 14:08:50 »
Okay yeah that. That looks incredible. I like the separate key for the up and down wave, because it gives us variance in the stars. The stars could also be different themselves, like some of them in the different stages of the animation, giving it more realism. Other than that, the only thing I don't like is that one star under the rainbow... it probably won't come out very well in the dyesub.
Offline Zifle
  • Nyaaa
« Reply #109 on: Sun, 30 October 2011, 14:27:36 »
Thanks for the positive feedback so far, just trying to make it more "real" ^.^
Quote from: Ragnorock;442324
Understandable, I mostly just wanted to see how it would look (also to give it even more variance).
If anybody (Hazeluff? =D) wants the psd, you can grab it here.
It has the keyboard, and each of the 4(5) different suggestions. I'm not really good with vector graphics (neither am I with bitmap, but what can you do?), so I would suggest Hazeluff (or someone else, if they want to) convert the finalized images to svgs.
I like cats.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #110 on: Sun, 30 October 2011, 14:50:04 »
Quote from: Zifle;442331
I just made them into some svgs. Here's the pictures of them. (It's not a 1:1 copy, I had some files and just added the things you did = D)
[ Attachment Invalid Or Does Not Exist ] 30375[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 30384[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 30385[/ATTACH]
« Last Edit: Sun, 30 October 2011, 19:54:47 by hazeluff »
Offline Zifle
  • Nyaaa
« Reply #111 on: Sun, 30 October 2011, 15:03:53 »
Quote from: hazeluff;442341
(Attachment Link) 30375[/ATTACH]
(Attachment Link) 30377[/ATTACH] (Attachment Link) 30376[/ATTACH]
I like it ! Perhaps the rainbow on the backspace should get cut slightly, to fit within the keycap itself, but apart from that, it's great ! (>^.^)>
Edit: I should have noted on the blue-background-keys I posted earlier, that I'm not completely confident it's the exact color, but it should be fairly close to that which was stated in the OP (and used in \KL's GB). I'm especially thinking of the purple in the rainbow. Perhaps we should try with a slightly lighter purple to get some more contrast?
« Last Edit: Sun, 30 October 2011, 15:06:49 by Zifle »
I like cats.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #112 on: Sun, 30 October 2011, 15:19:19 »
Quote from: Zifle;442350
I don't think the little bit on the backspace matters as it's just a design we send them.
As for the colors, I agree that maybe we want a lighter purple or a lighter blue keycap. But since that's not decide, we'll just leave it till it needs changes.
Offline Zifle
  • Nyaaa
« Reply #113 on: Sun, 30 October 2011, 15:26:32 »
Quote from: hazeluff;442353
Right, didn't think of that <_<
I like cats.
Offline Ragnorock
  • Group Buy Guy
« Reply #114 on: Sun, 30 October 2011, 15:41:18 »
In the actual SVG it does, exactly what we send them is what they print aside from positioning. However I'd like to see the rainbow go as close to the edge of the printable area as possible, so if you want to run the rainbow on the two other keys up to the edge that works for me too. There's a lot of controversy over how dark the blue from /KL's gb is, but its a medium blue and a darker purple would provide decent contrast with it, but the darker colors aren't going to show up very well regardless since it's on blue and not white... so expect that purple isn't going to be very visible regardless.
Hazeluff, whenever you've got SVGs you're good with me sending into Melissa for her to give the thumbs up/down go ahead and send them to me in an email. You should still have my email from the other gbs but if you don't lmk and I'll PM it to you.
Offline tsangan
  • 1000/600
« Reply #115 on: Sun, 30 October 2011, 15:47:43 »
Shouldn't the SVG be on white because the keycap is blue?
Keyboardless
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #116 on: Sun, 30 October 2011, 15:56:43 »
Quote from: Ragnorock;442358
I've made the rainbows touch the edges as well and just sent you an email with the files. Let me know if anything else is needed.
I am so very excited.
Quote from: tsangan;442359
Don't worry, those are just PNGs. It's just to show you guys roughly how it'll look. I've removed the blue background in my SVGs.
Offline tsangan
  • 1000/600
« Reply #117 on: Sun, 30 October 2011, 16:00:29 »
Oh man this is so awesome lets get this GB up and running!!!!!!!
Keyboardless
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #118 on: Sun, 30 October 2011, 16:03:12 »
Quote from: tsangan;442362
My level of excitedness is at "Little Schoolgirl screaming about Justin Bieber"
Offline noodles256
  • le legendary
« Reply #119 on: Sun, 30 October 2011, 16:07:28 »
in for the blue!
AF | Ducky YOTD |
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #120 on: Sun, 30 October 2011, 16:09:45 »
I thought I was joking when I suggested this buy, but this is shaping up to be epic.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #121 on: Sun, 30 October 2011, 16:25:12 »
Quote from: hashbaz;442368
I think you need to make more jokes. Cos you seem to be made of epic.
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #122 on: Sun, 30 October 2011, 16:42:09 »
Best joke ever. I gotta get a cherry board that isn't backlit so I have somewhere to put these and the portal keys. Probably gonna get a WASD soonish.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Oqsy
« Reply #123 on: Sun, 30 October 2011, 17:56:44 »
The small rainbow looks like rainbow poo. I'd like it more if it were the original thick rainbow the size of poptrrt
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline NumberJ
« Reply #124 on: Sun, 30 October 2011, 18:55:32 »
Interested.
edit:
in the blue set
« Last Edit: Sun, 30 October 2011, 22:25:55 by NumberJ »
Offline oneproduct
  • @Ubisoft
« Reply #125 on: Sun, 30 October 2011, 20:56:52 »
Fan of the blue.
Layout: Colemak
Offline Ragnorock
  • Group Buy Guy
« Reply #126 on: Sun, 30 October 2011, 22:45:02 »
Quote from: Oqsy;442395
Hell, that makes it even more funny imo.
« Reply #127 on: Sun, 30 October 2011, 23:02:51 »
If we can go to the edge of the keycap, why don't we add in as much blue background as possible by having another colour (darkerbluebackground) on the white keycaps? that way it's got some amount of background there. I think it could look better.
Here's a picture showing what I mean.
[ Attachment Invalid Or Does Not Exist ] 30397[/ATTACH]
Thoughts?
Edit: Please forgive white lines between my hastily added background and the rainbow that's already there.
Offline Kick
  • Fuego
« Reply #128 on: Sun, 30 October 2011, 23:22:45 »
Too much rainbow,imo.
I'd sport that keyboard design in the rainbow district of Hollywood
of course, no offense intended
Offline Ragnorock
  • Group Buy Guy
« Reply #129 on: Sun, 30 October 2011, 23:51:55 »
What I meant by the rainbow going to the edge of the svg is not that it will actually print to the edge of the keycap, but that it should be at the edge of the image to extend it as much as possible. I honestly do not know how close to the edge of the keycap they can print. We'll know that tomorrow.
« Reply #130 on: Mon, 31 October 2011, 00:52:15 »
It'll also affect the final graphic, as once we know what borders there are, we will be able to get it to line up properly.
Offline Ragnorock
  • Group Buy Guy
« Reply #131 on: Mon, 31 October 2011, 02:08:59 »
From what I understand, Melissa does that part herself, since she takes the SVGs and positions/scales them to look best on the keycaps.
Offline noodles256
  • le legendary
« Reply #132 on: Mon, 31 October 2011, 11:42:42 »
in for the white with blue on it!
AF | Ducky YOTD |
Offline Ragnorock
  • Group Buy Guy
« Reply #133 on: Mon, 31 October 2011, 11:51:16 »
I don't want to do blue bg on a white keycap, I'm down with either white or blue now that blue has the stars... and I'm leaning toward blue.
Offline hashbaz
  • Grand Ancient One
« Reply #134 on: Mon, 31 October 2011, 11:53:24 »
Quote from: Ragnorock;442659
Seconded.
Offline tsangan
  • 1000/600
« Reply #135 on: Mon, 31 October 2011, 12:02:15 »
blue bg on white key would look weird because you'll see the limitations of Signature Plastic's machines and for all you know it could come out to have weird edges ;<
Keyboardless
Offline noodles256
  • le legendary
« Reply #136 on: Mon, 31 October 2011, 12:16:56 »
in for blue
AF | Ducky YOTD |
Offline yjhuoh
« Reply #137 on: Mon, 31 October 2011, 13:57:26 »
yes
Offline Ascaii
« Reply #138 on: Mon, 31 October 2011, 14:16:07 »
id say blue, but I think SP is limited to white caps for their dye sublimation process. No way they could sublimate the entire cap, and doing the entire top of the cap might not be possible...can you write melissa and see if this is possible please?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #139 on: Mon, 31 October 2011, 14:25:02 »
Quote from: Ascaii;442773
I'm pretty sure he's already on that.
Offline tsangan
  • 1000/600
« Reply #140 on: Mon, 31 October 2011, 14:27:23 »
Nah blue is available, \KL has a dyesub groupbuy on blue keycaps
Keyboardless
Offline Ragnorock
  • Group Buy Guy
« Reply #141 on: Mon, 31 October 2011, 15:24:37 »
Okay, just fired off the email. Here goes nothin!
Offline Zifle
  • Nyaaa
« Reply #142 on: Mon, 31 October 2011, 15:27:54 »
Quote from: Ragnorock;442842
*crosses fingers*
I like cats.
Offline RColinTaylor
« Reply #143 on: Mon, 31 October 2011, 15:29:12 »
I think shes starting to hate the city of Pullman.
I like my Browns more than my Blues.
Offline Ragnorock
  • Group Buy Guy
« Reply #144 on: Mon, 31 October 2011, 15:35:09 »
Job security man!
Offline deadnoob
« Reply #145 on: Mon, 31 October 2011, 16:42:09 »
Definitely interested in this Although it seems like it is already going to happen, figured I'd say anyways.
Offline Ragnorock
  • Group Buy Guy
« Reply #146 on: Mon, 31 October 2011, 18:13:23 »
Okay just got a reply and started a brief convo about it. She's going to run a test print of them tomorrow to see how they look. The only problem that I forgot about is that they can't dyesub white. That only eliminates the stars, but unless you want to do the stars in a different color, we're going to have to do without them. I'm not sure whether she's going to print them on blue or white keycaps... but hopefully both.
Offline DeadJenkins
« Reply #147 on: Mon, 31 October 2011, 18:14:55 »
Super interested in the blues
Offline bloodygood
« Reply #148 on: Mon, 31 October 2011, 18:41:02 »
Quote from: Ragnorock;442942
Perhaps the possibility of doing a light yellow for the stars? Since that technically seems appropriate as it would be light and still show off the effect we are looking for.
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
Offline noodles256
  • le legendary
« Reply #149 on: Mon, 31 October 2011, 18:49:15 »
i actually prefer the blues. they look sick
AF | Ducky YOTD |
