Author Topic: Bored at work so I'm going to share my thought's on Mx Browns.  (Read 4450 times)
Offline wompwomp
« on: Fri, 28 October 2011, 16:58:13 »
I am honestly very disappointed with them.
A little back of myself: My first mech board was a blackwidow, then a TKL filco with blues, then an IMB model M, and now a Filco ninja with browns.
It's going to be kind of hard trying to explain this so bare with me.
First, I absolutely adore blues. From their feel, to their sound, and even their color lol. I've tried black switches before at a local Fry's and really enjoyed the feel of linear switches, but I hated how much force they required. I really want a Red board but due to their availability, I have not been able to obtain one yet.
Anywho, so I revieced my Filco with browns about a month ago and figured I would love it since I enjoy light switches as well as tactile switches. My first impression was "these are horrible." The tactile bump was barely noticable (which btw I've read about this before hand) and it wasn't that light. I think this is primarily due to the fact that the tactile bump on browns is placed much higher than blues. Brown's just felt like a "dirty" switch IMO.
Since the blue's tactile bump is lower (I would say about the half-way point of the switch) it allows you to build momentum as you are pressing the key down, so that when you do hit that "bump," you don't really have to add more force. Browns on the other hand, have their tactile bump much higher and that makes the switch require much more force from the start. I want to say almost like rubberdomes but not to that extent. You guys kind of get what I'm saying? I don't know, this is jsut my opinion.
I will probably end up selling my Filco with browns and just wait for the QuickFire to be release w/ reds.
Another note, I know statistically browns are supposed to be lighter than blues, but to me it felt like the complete opposite.
Offline bloodygood
« Reply #1 on: Fri, 28 October 2011, 17:06:37 »
Incase you haven't been around much recently, I believe there are 3 new keyboards around that are mx reds, so you might actually have your chance to test those sooner than you may think. their force is very similar to browns, but they do have the linear switches.
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
Offline slueth
« Reply #2 on: Fri, 28 October 2011, 17:06:47 »
It depends on the keycaps you use them with, I love the mx browns on my noppoo , while with ABS key-caps they felt crappy.  Also if you press on them slowly, they feel horrible. I also think blues feel the worst when you press on them slowly .
Offline bloodygood
« Reply #3 on: Fri, 28 October 2011, 17:10:34 »
Quote from: slueth;441398
I have heard many people saying that if you get a filco you should immediately replace the 37-keys with a set of pbt and you will enjoy your keyboard significantly more.
Offline HWI
« Reply #4 on: Fri, 28 October 2011, 17:15:11 »
If you think browns aren't that light than you'll probably think the same thing of reds, they feel pretty similar aside from the slight tactile bump in browns. Also, the quickfire w/ reds is already available in Asia, you can buy it from PCHome.
Bottom Out Like A Boss
Razer BWU | Ducky DK-1087 | Noppoo Choc Mini | CM Storm QFR | KBT Race
Offline noodles256
  • le legendary
« Reply #5 on: Fri, 28 October 2011, 17:17:17 »
get some clears
AF | Ducky YOTD |
Offline bloodygood
« Reply #6 on: Fri, 28 October 2011, 17:22:43 »
Quote from: HWI;441402
Do you have a link to the quickfire on PChome?
« Reply #7 on: Fri, 28 October 2011, 17:58:20 »
Quote from: bloodygood;441409
http://geekhack.org/showthread.php?22303-CM-storm-quick-fire-rapid-impression&p=422401&viewfull=1#post422401
Cheers!
Offline bloodygood
« Reply #8 on: Fri, 28 October 2011, 18:55:18 »
Quote from: dante;441464
I would like to see a video of someone typing 70+ wpm on browns without bottoming out.
I like browns but they need just a little more key travel.
Well I do type 85+wpm normally but 70+without bottoming out.. I am not quite sure if I can manage that. I will give it a few attempts and see how it goes.
Offline 500_pts
« Reply #9 on: Fri, 28 October 2011, 18:57:43 »
at first i felt the same about my browns, they didnt really feel that great, but it was my only board so i stuck with and and used it all day errday for 9+ months. Then i got a topre, and clears, and blues. My browns lay in the dark, long forgotten. But just recently ( in the past week ) i switched back to my browns and i must say I have fallen in love with them all over. They feel so smooth and buttery for some reason. It may be because the board is well used and the tactile bump could be smoothed out a bit, im not really sure. But i can feel the bump very well now, and damn it is just so smooth and satisfying. My advice, keep em, step away, then come back later.
REALFORCE 86u | HHKB Pro 2 | Filco TKL| Filco TKL | Leopold TKL | KBT Race
Offline bloodygood
« Reply #10 on: Fri, 28 October 2011, 18:59:42 »
Quote from: dorkvader;441422
Cheers!
I would also like to mention that the Corsair K60 has red keyswitches.
http://www.corsair.com/vengeance-gaming/vengeance-gaming-keyboards/vengeance-k60-performance-fps-mechanical-gaming-keyboard.html
and also the Leopolds come with red switches, in Black, White, and both of those options in Otaku
http://elitekeyboards.com/products.php?sub=leopold,tenkeyless
« Last Edit: Fri, 28 October 2011, 19:06:02 by bloodygood »
Offline noodles256
  • le legendary
« Reply #11 on: Fri, 28 October 2011, 18:59:47 »
i like my clears best
AF | Ducky YOTD |
Offline Lethal Squirrel
  • I <3 60%
« Reply #12 on: Fri, 28 October 2011, 19:53:13 »
I feel your cherry brown disappointment pain. :(
so far I've been disappointed at everything except blues.
Offline c0rbin
« Reply #13 on: Fri, 28 October 2011, 20:01:30 »
Here's another vote for replacing your keycaps with PBT... makes a huge difference.
Stock Filco keycaps feel cheap and horrible. I was disappointed with my board until I replaced the key caps.
Filco Majestouch-2 Tenkeyless Cherry MX Brown w/ PBT caps and O-ring mod
Offline noodles256
  • le legendary
« Reply #14 on: Fri, 28 October 2011, 20:02:23 »
Cherry browns are disppointing. Least favorite switch. but it is all preference.
BTW,
Please help me win a dorm makeover contest by clicking the link and liking that picture. thanks guys!
http://www.facebook.com/photo.php?fbid=10150336691004022&set=a.10150336690779022.353935.6132634021&type=3&theater
AF | Ducky YOTD |
Offline noodles256
  • le legendary
« Reply #15 on: Fri, 28 October 2011, 20:14:59 »
It's tough to say now since I really like the clears, but Blacks and Blues as of now.
Probably clears and Blacks after I give the clears more time. White and Black, its a civil war or switches.
BTW,
please help me win a dorm room makeover contest by following the link below and clicking like on that picture. Thanks guys!
AF | Ducky YOTD |
Offline HeavyArms
  • "Lit"
« Reply #16 on: Sat, 29 October 2011, 02:13:39 »
is it weird that I love both the browns and blacks? -___-
so much hate on my favorites! Maybe my fingers are confused. :frown:
try reds I dont like them that much so you may love them!
Head in the clouds.
fossala
  •  Guest
« Reply #17 on: Sat, 29 October 2011, 04:43:56 »
Check out ergo clears, they are as light as browns with more of a tactile bump.
Offline Lanx
« Reply #18 on: Sat, 29 October 2011, 09:16:55 »
yea you really have to mod to ergo clears if you were disappointed with browns. if you use blues and wanted more tactile or same as blues in browns, blues are more tactile, if you think it was lighter, that is just so it can "spring up" the stem since they clack so, really about the same force.
Offline Gerk
« Reply #19 on: Sat, 29 October 2011, 14:13:24 »
Every day all day long ... sorry, not going to make a video for you though, but I'm sure lots of people can do this.  I can do better with browns than with blues in fact -- not to mention that they browns are so much quieter (especially when you are not bottoming out).
Rosewill RK-9000RE (reds) | Das Keyboard Model S Professional Silent (browns) | Leopold TKL (browns) | F21-7D "Mechanical Keyboard" (Blue Alps) | Filco Majestouch TKL (blues) | Goldtouch V2 x 2 | Matias Ergo Pro x 2 | Kinesis Freestyle Pro (browns) | Kinesis Freestyle Edge (reds)
Offline Ascaii
« Reply #20 on: Sat, 29 October 2011, 14:19:27 »
honestly you sound like a prime canidate for ergo clears, I had the exact same feelings about blue+brown switches and have moved to ergoclears for my work board.
Offline Oqsy
« Reply #21 on: Sat, 29 October 2011, 14:33:42 »
Regarding blues; i've noticed a big difference between nib plate mounted vs vintage pcb mounted.
The new plate mounted ones feel more crisp, precise, and the tactile feedback is more obvious and thus helpful.
Vintage blues on the pcb feel like junk in comparison. Almost like they're gummed up inside(they're not, I checked).
Keycaps do make a difference. Old thick cherry caps, pbt or abs doubleshot beat the wafer thin abs that are standard on almost everything currently sold. It's a shame that thick beefy caps are dead. Perhaps we should urge clickclack to add thick, quality standard sets to his catalog, and produce them in volume large enough not to be collectibles ;)
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Surly73
« Reply #22 on: Sun, 30 October 2011, 07:30:34 »
I am also disappointed in browns when I "analyze" them.  By that I mean when I play with the switch, try to feel the tactile hump etc...etc...  When I use a keyboard with browns, I feel no tactility at all.  That being said, if I use a keyboard with blacks it feels distinctly different.  So browns don't have the rubber dome/Topre high tactility poppiness, but they are certainly different from linear.  I find the brown switch to feel a little gritty and I can tell that the tactility is from the leaf rubbing over a hump in a piece of plastic.
That being said, amongst many boards I've tried, I am the fastest, most comfortable, and most accurate on my board with MX browns.  It's the keyboard I most want to type on if I have a lot of heavy typing to do.  My favourite switch is the Topre, but the only board I've had was a 55g.  When analyzing the 55g Topre switch (see my first paragraph) it was heaven.  When typing, I could never really build up speed with a relaxed approach.  It felt like I was stabbing at each key - waiting for the complete press/release instead of flowing from key to key like with the browns.  I was slower on the 55g Topre than on a model M, so it isn't pure key weight that was causing this impression.
I still plan to try a lighter, variable force Topre board.  I was also interested in trying clears or ergo clears but there's no real budget for more keyboard toys right now.
