Author Topic: Where to get blank keycaps with text on the lower side (bottom).  (Read 6063 times)
Offline zeddez
« on: Sat, 29 October 2011, 20:38:23 »
Hi ive been searching all over to find any keys that look like the ones on this video.. have to link the video since i cant find the keys anywhere..  its the first keyboard he/she is showing.. they are blank on top but with text on the lower side of each key.. im soon going to buy the daskeyboard ultimate with all blank keys.. but i would really like to have these blank ones with those small writings on the bottom side..  so that if i have to find those really uncommon shift+key binds i always have the option to look as a last case..
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #1 on: Sat, 29 October 2011, 20:39:54 »
You didn't post the video, but I'm willing to bet they were Filco Ninja keys. Qtan sells some white PBT variants in his store. He may also have black ones, but I can't remember.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Shatterist
« Reply #2 on: Sat, 29 October 2011, 20:40:30 »
Well you haven't actually linked anything. As to what you've been talking about you probably should look for something from
http://www.vendio.com/stores/E-sports-Gaming-equipments/category/pbt-key-caps/catId=3982960
And what you're looking for are side printed keycaps
Offline zeddez
« Reply #3 on: Sat, 29 October 2011, 20:41:26 »
i tried to edit the post but couldnt paste the video..  but if you youtube after this **Cherry MX Blue, Red, Brown typing sounds** the first keyboard that is shown in the video..
Offline zeddez
« Reply #4 on: Sat, 29 October 2011, 20:43:08 »
Ok there seems to be one on the vendio website.. thank you so much.. now i just need to find a good shop close to me in europe =)
Offline Quarzac
  • A very busy dude!
« Reply #5 on: Sat, 29 October 2011, 20:44:43 »
Looks like a video posted by a geekhacker, probably Noodles. Those are indeed ninja caps on a Leopold. You can get white ones from Qtan, and he also sells gold printed ninja caps, which are very similar to those in the video. Ninja caps pop up here on the classifieds from time to time too, and you may be able to find some on eBay now that you know what you're looking for.
Offline zeddez
« Reply #6 on: Sat, 29 October 2011, 20:45:01 »
Btw would the hold the same feel and quality as the daskeyboard standard keys.. or perhaps they are of even higher quality ?
Offline Gin
« Reply #7 on: Sat, 29 October 2011, 20:59:18 »
Quote from: zeddez;442037
I think daskeyboard uses PBT key caps for their default set. So the ninja PBT keycaps from Qtan's website is a perfect set for it if you want keys of the same feel.
