Author Topic: Help - key presses do not register occationally  (Read 2384 times)
Offline RandomVariable
« on: Sun, 30 October 2011, 13:19:54 »
Until 2 weeks ago I have been using HHKB Lite with great satisfaction. Then I heard about mechanical keyboards and wanted to give a try. Ordered a Filco Blue tenkeyless. It occasionally missed key strokes, like on average 1 in 25 key presses did not type. When it missed key stroke I would hit that key several more times and it would then register. Needless to say I sent it back as defective.
Next I ordered a KBC Poker Black. I loved the keyboard and the feeling of Cherry Black's. However, to my deep disappointment, I am having the same problem although to a lesser extend. That makes me think that he problem is with me and not the keyboards.
I have two Linux systems (running on Suse 11.3) both of which exhibit the same problem. The missed keys are usually at the start of a word, as if the KB needs to warp up. The situation is noticeably worse in Firefox. For example I am having greater difficulty writing this post, compared to writing some random text in a plain text editor (kwrite), or in a terminal.
The hardware info regarding the keyboard shows as below:
Model: Holtek USB Keyboard
Driver: usbhid
Resources - baud: 1,500,000
xkbcmodel: pc104
xkbrules: xfree86
Any insight will be greatly appreciated. I love this keyboard (or any mech keyboard for that matter). But sadly it is unusable as is. (I do bottom out the keys, so non-actuation should not be an issue)
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #1 on: Sun, 30 October 2011, 13:23:56 »
I had that problem in Google Chrome in Ubuntu. It turned out the Adblock plugin wasn't playing nice. Try disabling everything not essential to OS life and seeing if the problem persists. Or try your HHKB, since that didn't seem to give you trouble.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
« Reply #2 on: Sun, 30 October 2011, 19:27:35 »
I am now typing this on a Mac Air (using Safari) - no keys are skipping, thus confirming that the keyboard is not defective.
Then the most likely culprit must be a conflict with the keyboard's firmware and the Linux keyboard driver. I wonder if the Holtek chip on the KBC has known incompatibilities with Linux.
Offline Tony
« Reply #3 on: Sun, 30 October 2011, 21:39:55 »
Keyboard drivers are full of holes, you should expect it to happen from time to time. Or you may want to update your drivers.
Have you tried mech keyboards with a Windows computer? I have no problems with them.
woody
  •  Guest
« Reply #4 on: Mon, 31 October 2011, 04:48:05 »
Quote from: RandomVariable;442413
Holtek on Filco - definitely no.
Offline mich
« Reply #5 on: Mon, 31 October 2011, 07:28:16 »
Are you sure it didn't happen with HHKB?
« Reply #6 on: Mon, 31 October 2011, 10:20:24 »
I now tried it with a Windows laptop. Does not seem to have any such problems (It works - it is alive !)
Yes I am sure - I have been using HHKB Lite for 6 or 7 years now, no such problem at any time.
It feels like the Linux OS expects a longer keypress signal and the board sends a shorter one (at times).
Anyway, sounds like I have a life-is-too-short-to-solve-this kind of a problem. So I will just wait until my next upgrade cycle, which is coming shortly. New Linux OS (can never give this up), and new motherboard and such. Hopefully I will be able to join the community of mechanical keyboard users then. :)
« Reply #7 on: Mon, 31 October 2011, 17:20:29 »
Quote from: ripster;442666
Sounds like a RandomVariable.
Yes indeed. The function that maps a key press event to one of two outcomes {Registered, NOT Registered} is a random variable.
Further, the function that maps a given number of key presses to total number of NOT registered key presses is also a random variable. This one may appear to follow a Binomial distribution, but the likelihood of a failed key press is not uniform for all key presses. A key press is more likely to fail when I resume to type after a brief pause.
I shall use this as an example in my statistics class.
Offline biochem
« Reply #8 on: Mon, 31 October 2011, 18:20:35 »
Is it stochastic?
Filco MJ2 tenkeyless (blues)
Heatware
« Reply #9 on: Mon, 31 October 2011, 18:32:59 »
Quote from: biochem;442945
Is it stochastic?
Or probabilistic. There is a slim probability that a key press will not register. This is the problem that I am trying to solve.
« Reply #10 on: Sat, 19 November 2011, 15:10:11 »
I found a way of making KBC Poker work with my particular Linux system and wanted to share it with the community.
I attached a PS2 adapter (that was lying around from old days) and connected the KBC through a PS2 port. The KBC works fine now and I am enjoying it very much. Apparently (and thankfully) it has built-in PS2 support.
I read some about USB vs PS2 for keyboard connection and was surprised that there is no clear disadvantage of using a PS2. Somehow I had the impression that PS2 was inferior to USB in this regard.
