Author Topic: Do Cherry MX Switch fit on Filco ?  (Read 8239 times)
Offline jaelink
« on: Mon, 31 October 2011, 03:59:09 »
Hey everyone,
I have a filco majestouch red switch and i would like to know if this keys (MX CHerry switch) would fit on my filco and if they are the same size are the actual keys. Because I have a friend who have buy this keys and they seem to not be exactly the same size.
Thanks.
fossala
  •  Guest
« Reply #1 on: Mon, 31 October 2011, 04:03:05 »
The switch or the keycaps?
The switches need to be plate mounted ones (his may be pcb). As for the keycaps they may fit but be the wrong profile.
[ Attachment Invalid Or Does Not Exist ] 30402[/ATTACH]
Offline jaelink
« Reply #2 on: Mon, 31 October 2011, 11:37:51 »
Thanks, but how to know if the profile is wrong or not ?
Offline pitashen
« Reply #3 on: Mon, 31 October 2011, 11:40:35 »
which profile does filco use? and which one does Cherry Corp use?
Offline jaelink
« Reply #4 on: Mon, 31 October 2011, 13:24:47 »
Sry i'm noob and i don't know what mean "profile" and "cherry corp" :p
I use a filco with red switch and keycaps made of ASB material
Offline pitashen
« Reply #5 on: Mon, 31 October 2011, 15:09:38 »
Quote from: jaelink;442723
I actually found the answer i posted above in wiki. You should go take a look as well.
Offline jaelink
« Reply #6 on: Mon, 31 October 2011, 19:30:40 »
I didn't find anything  on wiki, do you have the answer or a link plz ?
Offline jaelink
« Reply #7 on: Tue, 01 November 2011, 09:35:46 »
I put some keys on my filco it fit perfectly but they stick out about 1mm higher than the rest. What keys i need to not have problems ?
fossala
  •  Guest
« Reply #8 on: Tue, 01 November 2011, 10:27:18 »
How much are you willing to spend? There is always the group buy.
Offline jaelink
« Reply #9 on: Tue, 01 November 2011, 15:57:27 »
About 50$. I was thinking about buy some keycaps on wasdkeyboards.com, but do you know if they fit on a filco and if they are exactly the same size (not as my friends's keycaps) ?
Offline pitashen
« Reply #10 on: Tue, 01 November 2011, 16:48:52 »
WASD fits filco. I believe it is stated on their website that they are compatible
« Reply #11 on: Tue, 01 November 2011, 20:40:16 »
Quote from: jaelink;443572
Yeah, I'd go WASD. You can get a custom set pretty cheap, too.
Also, there are pictures of keys next to rulers in the wiki (somewhere) so you can compare to see how tall they are.
Offline Lenny_Nero
« Reply #12 on: Wed, 02 November 2011, 18:09:11 »
Quote from: jaelink;442988
http://geekhack.org/showwiki.php?title=All+About+Keys
http://geekhack.org/showwiki.php?title=Key+Reference+-+Pics+and+specifications+for+various+manufacturers+keys
Must admit they were not easy to find
Filco Zero, Viglen DFK 2020UKF104, DTK SPK-102a, Panasonic Biz 500
Ducky 1087,  Chicony KB-5191, G80-1856HQMGB Cherry G80-1000HFD and others
 G80-11908HRMIT, Tipro MID-KM128a, Access AKEOXPB312/2 (20x7), Access AKEOCTI635/1(15x6)
Offline Lenny_Nero
« Reply #13 on: Wed, 02 November 2011, 19:32:36 »
I was sorta ripping the piss.
Its why I always have such a low post count at places,
I have always found you learn more from doing it yourself rather than wanting to be spoon fed.
Did my learning on Usenet where you dont ask silly questions and get away with it.
I read this place for ages before I joined because the answers were almost always there asked by another first.
That said the two that would always have the needed truth dont seem to post here anymore :(
With me being an ALPS fan you will be able to work out them names.
As for the wiki search I dropped down the wiki menu at the top of the page for the first link,
and then scrolled down a few lines on that page to where the link for Key Reference Wiki info was in big letters.
Does the other place even have a wiki ??
...and what would you know about them wiki's anyway :p
