Author Topic: Laptop keys replacement for mechanicals. Possible!  (Read 2681 times)
Offline thegt1
« on: Mon, 31 October 2011, 12:44:30 »
Hi fellows, i have a laptop that have what can be consider the worst keys/switches in the whole planet, i did a search for laptop key replacement and was unable to find anything on the topic.
Have anyone done a switch for mechanicals on one of these, or is there any other way to improve the quality of this things. Any input, threads, help will be greatly appreciated.
Offline iindigo
« Reply #1 on: Mon, 31 October 2011, 12:56:03 »
Unfortunately, with laptops you're pretty much stuck with the keyboard it comes with. This is why keyboard feel, IMO, is a more critical factor when laptop shopping than raw specs.
Offline Lanx
« Reply #2 on: Mon, 31 October 2011, 13:41:12 »
laptop keyboards are superthin, like 5mm thickness or something lol, and that's the whole board (you can remove the whole keyboard, it's like 10 sheets of paper thick)
Offline whiskerBox
« Reply #3 on: Fri, 11 November 2011, 22:32:26 »
Geltac s400 hundreds have mechanical keys sort of?!
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Oqsy
« Reply #4 on: Fri, 11 November 2011, 23:33:03 »
"backlit mechanical membrane"
Wuh?
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline journeymangeek
« Reply #5 on: Fri, 11 November 2011, 23:40:20 »
Just use the amazing technology called USB to plug in a keyboard of your choice. Otherwise, really try before you buy if you can.
Offline Konrad
« Reply #6 on: Sat, 12 November 2011, 00:13:06 »
Laptop keyboards are usually low-cost replaceable modules.  On some models just pulling the keycap off is a somewhat permanent issue which basically breaks it forever.  Those scissors switches can be a real ***** to reassemble without factory automation.
