Author Topic: Caps for Noppoo Choc Mini  (Read 3985 times)
Offline rich0d
« on: Tue, 01 November 2011, 07:56:44 »
I want to replace the caps on my mini - but I'll probably need to order a few custom ones as the FN, right Alt and Win key are the same size as a regular key. But what row would I get to replace them with? I'm also not sure if the right shift is the normal size either, ANSI layout keyboards aren't my native, so I'm kinda unsure of what is a regular sized one. :)
Thanks
[SIGPIC][/SIGPIC]
Offline SadButTrue
« Reply #1 on: Wed, 02 November 2011, 03:39:25 »
Why not go for a two-tone config?
I use a UK layout. These caps came off a Cherry:
[ Attachment Invalid Or Does Not Exist ] 30617[/ATTACH]
« Last Edit: Wed, 02 November 2011, 04:35:07 by SadButTrue »
Keyboards: Compaq 89u, Noppoo Choc Mini
Mice: KinzuAdder, DeathAdder, Zowie EC1, Logitech G5, Logitech G400, Zowie Mico, Puretrak Valor, Gigabyte M6900, Roccat Pyra
