Author Topic: THICK keycap set?  (Read 6619 times)
Offline HaiiYaa
THICK keycap set?
« on: Tue, 01 November 2011, 10:07:56 »
Hi
After trying some noppoo keycaps on my cm storm quickfire rapid I know I prefer THICK pbt or pom keycaps
Anyone know where to get that?
Offline bloodygood
THICK keycap set?
« Reply #1 on: Tue, 01 November 2011, 10:35:43 »
I think the only recent group buy going on for pbt keycaps is this one. http://geekhack.org/showthread.php?21177-new-group-for-KBC-keycaps-including-104 (ideal prices)
unless we manage to get a manufacturer to supply WASD with pbt.
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
Offline HaiiYaa
THICK keycap set?
« Reply #2 on: Tue, 01 November 2011, 12:21:44 »
thats the same that you can buy from qtan right? They do look quite thin if i look at ripsters thread with the keycaps
Offline bloodygood
THICK keycap set?
« Reply #3 on: Tue, 01 November 2011, 13:45:36 »
They look thick enough to me, but I am not the best judge I suppose.
PBT .8mm according to the wiki
a filco standard appear to be ABS .9mm
« Last Edit: Tue, 01 November 2011, 14:00:49 by bloodygood »
Offline jpm804
  • KeyCap Assasin
THICK keycap set?
« Reply #4 on: Tue, 01 November 2011, 13:53:47 »
Quarzac has a Gb for Black Cherry DoubleShots which are pretty thick..
http://geekhack.org/showthread.php?23218-25-Used-Cherry-Doubleshots-Round-2
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline bloodygood
THICK keycap set?
« Reply #5 on: Tue, 01 November 2011, 13:56:54 »
Quote from: ripster;443445
Numbers in the Key Ref wiki stickied above.
Is there any documentation on the original Dolch keycaps? I could not find them in the Wiki as far as I could tell. Ctrl+F to no avail, unless they are under another name.
Offline IvanIvanovich
  • Mr. Silk Underwear
THICK keycap set?
« Reply #6 on: Tue, 01 November 2011, 14:30:15 »
Dolch were made by Cherry, just in a different color.
Offline bloodygood
THICK keycap set?
« Reply #7 on: Tue, 01 November 2011, 14:32:46 »
So in other words that used cherry doubleshots group buy is probably exactly right for them.
THICK keycap set?
« Reply #8 on: Tue, 01 November 2011, 14:44:02 »
Cherry are thick, but abs. Not sure which is most important, thickness or material. The KBC PBT aren't thicker than stock keycaps, but they seem denser. The KBC POM 'jellies' seem to be thicker.
Offline HaiiYaa
THICK keycap set?
« Reply #9 on: Tue, 01 November 2011, 16:02:17 »
Quote from: bloodygood;443438
They arent that thick. Check out the noppoo key caps I was talking about
THICK keycap set?
« Reply #10 on: Tue, 01 November 2011, 20:32:32 »
I like the thick WYSE doubleshot keys I have, I paid $20 shipped for them. They're not the thickest (there was a topic on it once with some real monsters) They are ABS, though.
Also, WOW that's a pretty thick keycap! It's POM on the noppoo, right?
