Author Topic: Filco's internal connector?  (Read 4574 times)
Offline alaricljs
  • I be WOT'ing all day...
« on: Wed, 02 November 2011, 21:26:23 »
Any chance someone knows the make/model of the connector used inside an 87key Filco to connect the cable to the PCB?  I'm interested in both the connector and the receptacle.
Thanks
Filco w/ Imsto thick PBT
Offline ironman31
« Reply #1 on: Wed, 02 November 2011, 21:47:03 »
If it's the same as the Noppoo mini, I got one from Fry's. It's a molex .100 KK Housing & terminals 4 Cir. (2.54mm)
This is the best picture I could manage with a DROID camera
« Last Edit: Wed, 02 November 2011, 21:53:07 by ironman31 »
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline alaricljs
« Reply #2 on: Wed, 02 November 2011, 21:58:31 »
The one in a Filco is 2mm spacing, 5 pin.  And if that's the connector for the cable in your pic, it's HUGE compared to the Filco.
This one is 10mm wide, 3mm thick, 6mm deep.  As far as I can tell it's an attempt at a direct competitor to one of Amps connectors.
Offline laffindude
« Reply #3 on: Wed, 02 November 2011, 22:11:50 »
One of these? [ Attachment Invalid Or Does Not Exist ] 30708[/ATTACH]
I just pulled that one out of an old mouse.
Offline alaricljs
« Reply #4 on: Wed, 02 November 2011, 22:18:25 »
Yup, that seems to be exactly it.  And also, my plan worked.  I've been banging on the net for 2 days to find this thing.  45 minutes after I ask here, I find the damned thing.
It's a JST PH  5 position connector and SMT mount shrouded receptacle.
connector housing: PHR-5
connector pins: SPH-002T-P0.5S
SMT mount shrouded header: S5B-PH-SM4-TB
Now I need to figure out where to buy them in smaller quantities...
« Last Edit: Wed, 02 November 2011, 22:40:43 by alaricljs »
Offline laffindude
« Reply #5 on: Wed, 02 November 2011, 22:20:11 »
See if you can pull apart an old mouse and salvage it.
Edit, it is an MS mouse. I think I saw the same connector inside a MS keyboard too.
Offline bloodygood
« Reply #6 on: Wed, 02 November 2011, 22:27:06 »
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
Offline alaricljs
« Reply #7 on: Wed, 02 November 2011, 22:35:55 »
My primary interest is actually the PCB side... which no one seems to stock, even when they stock the cable side.
Offline laffindude
« Reply #8 on: Wed, 02 November 2011, 22:43:04 »
^Hence why I suggested pulling old mouse you don't need apart for it. Just desolder the receptacle from the PCB.
Offline alaricljs
« Reply #9 on: Wed, 02 November 2011, 22:44:16 »
Fixed the part number... wonder what they changed between the revisions....
http://parts.digikey.com/1/parts/1606546-conn-header-ph-side-5pos-2mm-smd-s5b-ph-sm4-tb-lf-sn-p.html
$.70 each
Offline alaricljs
« Reply #10 on: Wed, 02 November 2011, 22:44:51 »
I'm not about to pull apart ~50 mice :)  small quantity compared to the 1000 JST wants to sell me.
Offline laffindude
« Reply #11 on: Wed, 02 November 2011, 22:52:20 »
I don't think anyone has 50 old mice laying around ;o
Offline alaricljs
« Reply #12 on: Wed, 02 November 2011, 22:54:45 »
Well there are 2 complete sets of 50 that have the wrong PCB connector for super cheap ($7)... I've asked both sellers if they can substitute the right PCB end.
« Reply #13 on: Thu, 03 November 2011, 11:02:48 »
Quote from: alaricljs;444650
Can't you just use a normal 90 degree .1 spaced 5 pin header?
Offline alaricljs
« Reply #14 on: Thu, 03 November 2011, 11:07:42 »
I'm interested in giving people the option of using original parts from their KB... for instance either the Filco cable or the CMStorm extension to the external USB connector.
