Author Topic: I am in a dilemma right now...  (Read 2573 times)
Offline Pseudo
« on: Thu, 03 November 2011, 19:49:19 »
I want a TKL, MX red or clear (leaning toward clears) board.
Board I have pre-ordered right now is the Leopold White TKL Clear from EliteKeyboards.  Their site says shipping starts Nov. 10.
Anyone know of retailers that stock these kinds of boards besides EK? (US)
Reasons why I am reluctant to continue with the Leopold...
1. EliteKeyboards's return policy is dejecting. (Only 30 day returns for DOA, no exchanges or refunds.)
2. Their spacebar stabilizers have a different distance from the center, compared to other keyboards that use dummy switches for stabilizers. (Not sure if true, I think I read this somewhere.)
I currently have a Das S Blues.  Want something new, preferably quieter.  Was considering a Filco White TKL Brown from Amazon, but not sure if I want browns.  I think I'm just gonna bite the bullet and go with a Leopold.
Leopold FC200RE/AW MX Clear
Offline jpm804
  • KeyCap Assasin
« Reply #1 on: Thu, 03 November 2011, 19:59:58 »
If you are looking at a tenkeyless boards with clears there is not many options out there which it seems like you have done research on to know...
The spacebar thing only comes into play if you want to replace the keycaps with some other keys then it plays into the equation...the better question is whether you will like costar or cherry style stablizers( the ones that leo's have). I actually dont mind either, but some people like one over the other.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline RColinTaylor
« Reply #2 on: Thu, 03 November 2011, 20:10:02 »
If you really, really want a Red TKL and think the Leo stabilizers are a problem then get a CM storm from PChome.
The stabilizers, however, are not a problem unless you are trying to replace your keyboard.
I like my Browns more than my Blues.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #3 on: Fri, 04 November 2011, 09:58:12 »
and if you ever do need to replace that spacebar there are always people like me who are willing to mod one for you if you dont want to.
Offline N8N
« Reply #4 on: Fri, 04 November 2011, 10:08:05 »
If you have a razor knife, some old keycaps, a Dremel, some epoxy, a drill, and some spare stems and/or stabilizer thingys (you can buy those from WASD) you can make a jig out of a scrap 2x4 to make any space bar the right length work on a Leopold.  It's not that hard...
As others have said, the Leopold is really your only out of the box option for tenkeyless w/ clears unless you want to buy a Filco etc. and do a stem/spring swap (doable but not a quick project.)
Offline popol
« Reply #5 on: Fri, 04 November 2011, 10:53:33 »
They don't seem very professionnal and are for sure not client service oriented at all at EK. Greedy pigs to me.
fossala
  •  Guest
« Reply #6 on: Fri, 04 November 2011, 10:55:47 »
I thought EK where a good seller. Am I wrong?
Offline noodles256
  • le legendary
« Reply #7 on: Fri, 04 November 2011, 11:42:56 »
yup
AF | Ducky YOTD |
Offline noodles256
  • le legendary
« Reply #8 on: Fri, 04 November 2011, 12:07:45 »
I just returned my Filco Camo, because it was so expensive. Hassle free and easy
AF | Ducky YOTD |
Offline pitashen
« Reply #9 on: Fri, 04 November 2011, 12:54:34 »
Quote from: noodles256;445561
Er... why buy it the first place? If you considered it so expansive...
Offline alaricljs
  • I be WOT'ing all day...
« Reply #10 on: Fri, 04 November 2011, 12:59:08 »
noodles celebrates Free Feel Day
Filco w/ Imsto thick PBT
Offline noodles256
  • le legendary
« Reply #11 on: Fri, 04 November 2011, 13:07:49 »
Quote from: pitashen;445599
i was going to keep it until newegg had 20% off their boards. 2 boards for the price of 1
it was a tenkeyless so it really wasn't expansive persay
« Last Edit: Fri, 04 November 2011, 13:10:26 by noodles256 »
AF | Ducky YOTD |
Offline noodles256
  • le legendary
« Reply #12 on: Fri, 04 November 2011, 13:15:40 »
Quote from: ripster;445608
Thanks for raising our Filco prices Noodles..........
I also raised the bar for lower prices
AF | Ducky YOTD |
Offline noodles256
  • le legendary
« Reply #13 on: Fri, 04 November 2011, 14:35:27 »
Quote from: ripster;445620
You should have said it pinged.
did you have problems with your camo and your group buy caps? my left shift and caps locks always gets stuck on the side of the board.
AF | Ducky YOTD |
