Author Topic: Phantom pricelist  (Read 5093 times)
Offline Phantom
Phantom pricelist
« on: Fri, 04 November 2011, 09:20:42 »
The ordering system is up, so you can now order all parts you need to build you own Phantom keyboard!
The prices in the list are estimates and might change (most likely they will be cheaper in the end).
Shipping will be from US and Germany.
All prices are in $:
Code: [Select]
    Order-ID        |qty|price|description
    TEENSY          |  1|   18|Teensy controller
    PHANTOM         |  1|   35|Phantom PCB
    PHANSI          |  1|   35|mount plate ANSI (1.5,1,1.5 units)
    PHANSIWIN       |  1|   35|mount plate ANSI with WIN keys (1.25 units)
    PHISO           |  1|   35|mount plate ISO
    PHISOWIN        |  1|   35|mount plate ISO with WIN keys
    PH7BIT          |  1|   35|mount plate 7BIT
    MXRED           |  1|  0.6|MX red plate mount switch
    MXBLUE          |  1|  0.6|MX blue plate mount switch
    MXDARKBLUE      |  1|  0.6|MX dark blue plate mount switch
    MXBROWN         |  1|  0.6|MX brown plate mount switch
    MXCLEAR         |  1|  0.6|MX clear plate mount switch
    MXBLACK         |  1|  0.6|MX black plate mount switch
    MXGREY          |  1|    2|MX grey plate mount switch
    MXGREEN         |  1|    2|MX green plate mount switch
    DIODE           |  1| 0.02|n-key rollover diode
    STAB200         |  1|    2|MX plate mount stabiliser
    STAB400         |  1|    2|MX plate mount stabiliser
    STAB625         |  1|    2|MX plate mount stabiliser
    STAB700         |  1|    2|MX plate mount stabiliser
    STAB1000        |  1|    2|MX plate mount stabiliser
    CASE            |  1|   60|case for tenkeyless layout
    PHANTOMFUN      |  1|    2|Phantom function key
    PHANTOMMOD100   |  1|    2|Phantom 1 unit modifier key
    PHANTOMMOD125   |  1|    2|Phantom 1.25 units modifier key
    PHANTOMMOD150   |  1|    3|Phantom 1.5 units modifier key
    PHISOREDKIT     |  1|  125|Teensy/PCB/ISO plate/MX red with stabs
    PHISOCLEARKIT   |  1|  125|Teensy/PCB/ISO plate/MX clear with stabs
    PHISOBLACKKIT   |  1|  125|Teensy/PCB/ISO plate/MX black with stabs
    SOLDERING       |  1|  200|soldering
Please send a message to Phantom with lines of order-IDs and quantities separated by space.
Don't forget your e-mail address!!!
Example:
Code: [Select]
    TEENSY 1
    PHANTOM 1
    PHANSI 1
    MXRED 100
    DIODE 100
    STAB200 4
    STAB700 1
    your email address
« Last Edit: Fri, 04 November 2011, 10:16:22 by Phantom »
Offline litster
  • rare caps?! THAT'S A SMILIN
Phantom pricelist
« Reply #1 on: Fri, 04 November 2011, 10:38:27 »
I will add this information to the main thread as soon as I get to a real computer with a real keyboard and a real mouse  =)
Offline tsangan
  • 1000/600
Phantom pricelist
« Reply #2 on: Fri, 04 November 2011, 12:02:03 »
What kind of case is it?
Keyboardless
Offline litster
Phantom pricelist
« Reply #3 on: Fri, 04 November 2011, 12:04:10 »
It is a placeholder for now.  We don't have a case lined up yet, if ever.  We are investigating a few leads.  But at this time probability for it to come through is very low.
Offline tsangan
  • 1000/600
Phantom pricelist
« Reply #4 on: Fri, 04 November 2011, 12:09:42 »
Thats cool just wondering, also erm why is there ISO kits but no ANSI kits ;<
I doubt its a big deal to order them all separately though lol
Keyboardless
Offline litster
Phantom pricelist
« Reply #5 on: Fri, 04 November 2011, 12:11:30 »
I noticed the missing ANSI kit as well.  I think it is just an over sight.  I will later put together more detailed instructions so people know what PARTNUMBER to order for what they want.  :-)
