Author Topic: Easy entry of polish characters to an azerty keyboard...  (Read 3109 times)
Offline TacticalCoder
« on: Sat, 05 November 2011, 20:11:47 »
My girlfriend would like to input the polish characters with a diacritical mark: a, c, e, l, n, o, s, z and z  (there are two different z).     (I did put them here in ASCII because I'm lazy ; )
Can I easily add shortcuts to her Mac so that she can stays in AZERTY layout (not forcing her to switch to another layout) and then do something like: right alt + option + a = 'polish a'?
The default dead key thing she doesn't like that much and anyway it doesn't seem to be working that great: option + ` + c closes Chrome tabs etc.
So instead of composing using dead keys she'd rather add the nine additional shortcuts using some modifier.
So that's it: no alternative layout (no layout switching), no compose/dead keys.  How can I create the 9 shortcuts she wants?
(I'm very familiar with that kind of stuff on Linux but I'm no OS X guru so detailed instructions would be most welcome : )
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Sun, 06 November 2011, 00:43:01 »
It's been awhile since I needed to create a custom keymap on mac, but this might be of use.
Offline flyball
« Reply #2 on: Sun, 06 November 2011, 06:56:50 »
Quote from: TacticalCoder;446417
does she know what the option key is? i'm pretty sure chrome has never used the option key for anything
[SIGPIC][/SIGPIC]
« Reply #3 on: Sun, 06 November 2011, 08:54:43 »
Quote from: lysol;446541
Thanks a lot.  I downloaded Yukelele and created a new "layout".  I then put that layout in ~/Library/Keyboard layouts/ and now everything is working fine : )
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #4 on: Tue, 08 November 2011, 10:21:57 »
I think ControllerMate or Keyremap4Macbook is the way to go if you don't like to create a new layout. By the way layouts are just XML files if you open them up. Pretty easy to modify by hand.
« Reply #5 on: Tue, 08 November 2011, 12:56:25 »
Quote from: czarek;447974
Ah good to know, thanks!  I'm used to edit such things on Linux but didn't know anything about OS X: I didn't even check the kind of file "Yukelele" did crank.  She's away with her laptop as of now but out of curiosity once she gets back I'll "diff" the new layout I made her with the one I used as an example.
