Author Topic: HHKB Pro 2 Left FN key  (Read 2894 times)
Offline chel-
« on: Mon, 07 November 2011, 14:22:11 »
So I've been thinking about this for a couple days now and I'm not sure if my keyboard is faulty or maybe I'm just reading this wrong. On the back it says SW4 when turned on changes the left key beside alt (forgot what its called..the one with the diamond on it) to the FN key. When I turn it on it doesn't do anything however. Does anyone know if I need to turn one of the other switches on or something? Thanks.
Offline hcry4
  • HHKB Hoarder
« Reply #1 on: Mon, 07 November 2011, 14:54:43 »
It should work like the Fn key on the right side. All my switches are on, except #6.
Offline chel-
« Reply #2 on: Mon, 07 November 2011, 17:24:53 »
I'm not entirely sure but it seems like its malfunctioning. For instance right now I just have 3 and 4 on and it's swapped my left alt with the key right next to it (as if switch 5 was on, but its not right now).
Edit* nvm unplugging it did the trick.
« Last Edit: Mon, 07 November 2011, 17:31:21 by chel- »
Offline hcry4
  • HHKB Hoarder
« Reply #3 on: Mon, 07 November 2011, 17:26:09 »
Make sure to unplug and try turning on 1 and 2.
