Author Topic: can anybody tell me if its possable !!  (Read 1747 times)
Offline collector of junk
« on: Wed, 09 November 2011, 13:39:16 »
Is it possible to swap or replace keyboard controllers?
If both controllers have the same number of inputs i.e. bottom sheet 16 top 8
Would I have to trace every key on each board for example keyboard 1 when A is pressed its on 10 bottom plastic sheet, 2 top sheet
Keyboard 2 A= 16 bottom sheet /8 top sheet
So solder a wire from keyboard plastic sheets (membrane) to the new controller on the right pins
Any help many thanks
« Reply #1 on: Wed, 09 November 2011, 16:12:42 »
well yes (whats that burning smell!!!) i did mean solder to it via the socket
Offline wcass
« Reply #2 on: Thu, 10 November 2011, 14:56:11 »
you can swap controllers if:
  • the matrix is the same
  • you swap the membrane also
  • the controller is programmable
i do remember a mod someone did where they used a wireless keyboard controller - the matrix was almost the same, new column 6 was = to old column 2, new row 5 = old row 4, etc . they made an adapter to change the column/row order. one or two keys had to be remapped in software.
« Last Edit: Thu, 10 November 2011, 15:31:27 by wcass »
« Reply #3 on: Sun, 13 November 2011, 05:55:13 »
if its of interest to anyone the fujitsu fkb4700 keyboard has the same layout/spacings as a ibm 102 so a membrane swap wound work
