Author Topic: IBM Model M SSK: "Clack" before "Click" on Pressing  (Read 1645 times)
Offline bootstrap
    • epiguru.com - My Personal Website
« on: Fri, 11 November 2011, 12:04:26 »
Apologies for the terrible quality of the video (1 min 6 sec) below. It does, however, demonstrate the issue even with just the audio. The '! 1' key of my bolt-modded Model M SSK does not seem to be functioning properly. Pressing on the left edge of the key seems to be normal. However, pressing on the right edge of the key creates an extra resistance on the downstroke and a "clack" sound before the usual "click." Pressing on the middle of the key produces variable results. It seems like the spring in this key is buckling in the wrong direction. Or just not working as it should. I have reseated the key a few times without improvement. The spring looked normal by the eyeball test - my eyeballs, not an expert's.
[video=youtube_share;4fT3n9pema0]http://youtu.be/4fT3n9pema0[/video]
Two questions:
1. Will changing the spring of the key solve the problem?
2. Should/Can I use Sandy55's ChopstickODeath method to change the spring? (My wife told me to find a use for the chopsticks lying around in the kitchen or throw them away.)
The Best WordPress Theme Ever | Kinesis Contoured Model 100 | IBM Model F 1387033 "Space Unsaver" | CH Products DT225 Trackball x 2
Offline bootstrap
« Reply #1 on: Fri, 11 November 2011, 12:07:48 »
Quote from: ripster;450033
I'd just try reseating the key first.  Often happens when sent halfway around the world.
Thanks, but I've already tried that a few times. :(
Offline bootstrap
« Reply #2 on: Fri, 11 November 2011, 13:52:58 »
OK guys, jpc gave the solution, which was actually simpler than changing the spring. I swapped the stems of the '1' and '2' keys, and now both keys work great. How odd.
(Looks like the chopsticks are going in the bin.)
« Reply #3 on: Sat, 12 November 2011, 20:20:31 »
Quote from: bootstrap;450119
Quote from: ripster;450123
The McRip Effect.
Glad it worked for you. I don't think it's the McRip effect, but likely reseating the spring fixed your issue.
Offline bootstrap
« Reply #4 on: Sat, 12 November 2011, 23:50:40 »
Quote from: dorkvader;450833
Thanks. I think the '1' key was a real issue, albeit a small one that was easily fixed. Most likely a result of long-distance travel. The solution (stem swap) does make a cool party trick and might be helpful for noobs (like yours truly) to know if reseating the key doesn't work.
On the other hand, I'd be the first to admit that the louder-than-usual sound from the left Shift key (also fixed) was borderline McRip effect.
