Author Topic: Samsung branded Chicony  (Read 1967 times)
Offline REVENGE
« on: Sat, 12 November 2011, 19:35:54 »
« Reply #1 on: Sat, 12 November 2011, 20:56:34 »
on one of them, the J key is broken (you can probably glue it, though), but the caps are doubleshot, and the sliders are blue-coloured.
starts at $49.99, but you get two.
Offline False_Dmitry_II
« Reply #2 on: Sat, 12 November 2011, 21:52:49 »
I would assume they have different switches to each other. They don't look the same (but with chicony boards, who knows).
Offline Magna224
« Reply #3 on: Sun, 13 November 2011, 13:40:15 »
The one that they show looks to be real Blue ALPS. The other one has a gold label which from what I have seen is a good sign.
« Last Edit: Sun, 13 November 2011, 13:42:44 by Magna224 »
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline REVENGE
« Reply #4 on: Sun, 13 November 2011, 13:55:30 »
Quote from: Magna224;451228
I don't see any ALPS branding on the close-ups of the switches they provided, it could be a clone.
« Reply #5 on: Sun, 13 November 2011, 17:31:16 »
Quote from: ripster;451239
Both are blue complicated ALPS.  95% sure.
Nice! What makes you say that?
Offline Magna224
« Reply #6 on: Mon, 14 November 2011, 10:11:28 »
I determined it by the fact Blue ALPS weren't labeled in all the cases I have come across and that is the right shade of blue. The clones I have seen are a different shade. Gold labels also seem to show up during the time period of the Blue ALPS.
I was thinking I should increase my Blue ALPS stock but I shouldn't spend money until I get my spare PC sold.
