Author Topic: How long to break in L-TracX  (Read 3932 times)
Offline Minskleip
« on: Sun, 13 November 2011, 11:09:13 »
Yo ho's! How long did it take you to break in your L-Trac? I've had mine for two days now, and there's still a bit of jerk when I move the ball slowly.
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1 on: Sun, 13 November 2011, 16:08:26 »
Got mine used came broken in ;). For any trackball I recommend upgrading your ball to http://tinyurl.com/clslhgd .
Offline RPro
« Reply #2 on: Sun, 13 November 2011, 16:50:38 »
Mine still occasionally gets jerky, at least in feel, as if something got stuck in the rollers. Best thing to do is to spin the ball in all directions very quickly - that should smooth it out for a while.
« Reply #3 on: Sun, 13 November 2011, 17:35:10 »
This is why I wish they made a Laser DT225 with 5 button and some way to scroll using the ball without having to awkwardly hold a button down.
Offline Minskleip
« Reply #4 on: Mon, 14 November 2011, 12:37:36 »
I've bought extra switches and will assemble them during the week :D Hopefully I'll be worked in during that time.
Offline zareliman
« Reply #5 on: Sun, 20 November 2011, 17:43:19 »
Quote from: TheProfosist;451310
That costs more than my Trackball XD.
But, seriously, how do you know it would fit ?
Are L-Trac pool ball compatible ?
Offline bootstrap
    • epiguru.com - My Personal Website
« Reply #6 on: Sun, 20 November 2011, 22:54:18 »
Quote from: TheProfosist;451359
I second that.
The Best WordPress Theme Ever | Kinesis Contoured Model 100 | IBM Model F 1387033 "Space Unsaver" | CH Products DT225 Trackball x 2
« Reply #7 on: Sun, 20 November 2011, 23:30:00 »
Quote from: bootstrap;456532
I second that.
Hmm make our own theres definitely a market there.
Offline Oqsy
« Reply #8 on: Sun, 20 November 2011, 23:35:51 »
Yes. I need moar dpi. A separate scroll wheel makes the most sense.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
