Author Topic: Error 1935 with Cherry Tools on Windows 7?  (Read 7821 times)
Offline Nurburgring
« on: Tue, 15 November 2011, 15:30:44 »
I've recently got my first mechanical keyboard and it was cherry G80-8200LPBUS-2
Then, i downloaded Cherry Tools v5.8 and tried installing it when it gave:
Error 1935. An error occurred during the installation of assembly 'Microsoft.VC80.CRT, type="win32", version='8.0.50727.4053", publickKey Token="1fc8b3b9a1e18e3b", processorArchitecture="amd64". Please refer to Help and Support for more information.
I would really appreciate it if there is any fellow OEM cherry keyboard users out there with the POS (Point Of Sale, not Piece Of ****) programmable keyboard who experienced such problem.
FYI, i'm running on windows 7 x64 ultimate.
Again, thank you.
Gigabyte GA-MA790GPT-UD3H ||AMD II Phenom X4 B50 @ 3.6GHz || G.Skill Sniper 8GB DDR3 1866Hz || XFX Radeon HD 5770 1024MB || OCZ Agility 2 60GB SSD || Western Digital Caviar Black Enterprise 2TB & 500GB
Cherry G80-8200LPBUS-2
Offline cactux
  • Topre Knight
« Reply #1 on: Tue, 15 November 2011, 15:32:03 »
do they suport 64 bits? In windows you can normally configure each application to run in 32 bits
« Last Edit: Tue, 15 November 2011, 15:36:45 by cactux »
[FS]☠ The temple lol ->HERE<-
Offline Nurburgring
« Reply #2 on: Tue, 15 November 2011, 15:44:10 »
according to the official cherry software download page, the program supports it
through my research, it seems like there is issue with the microsoft .net framework or c+++, which is painful...
on that note, i didn't mind typing down the entire error message because not only does it make it more specific, i seriously LOVE typing on this cherry brown right now...!
this was my first cherry keyboard to every type on (first mechanical keyboard i typed on was buckling spring on ibm model m) and it properly demonstrates the name
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Tue, 15 November 2011, 17:10:54 »
Make sure you have the vc++ 2005 runtime packages installed both 32 and 64 bit.
« Reply #4 on: Tue, 15 November 2011, 17:52:18 »
Glad you finally got your board!
Offline Nurburgring
« Reply #5 on: Tue, 15 November 2011, 19:03:02 »
i really appreciate the recommendations but installing both version did not solve the problem...
thanks demik! i'm really happy that i was finally able to haha
« Reply #6 on: Wed, 16 November 2011, 08:39:43 »
Are you running the Cherrytools installer as admin?
Offline Nurburgring
« Reply #7 on: Wed, 16 November 2011, 11:41:54 »
Yes of course, i'm the only admin user of the computer.
Besides, the cherry tools installer is .msi package file, not an .exe file.
Therefore the only way to run it is with admin privilege which i have.
I just decided to do a format of the computer since it was about that time of the year. I'll post up to see how that goes.
Offline dimoniy
« Reply #8 on: Wed, 16 November 2011, 16:20:39 »
Quote from: Nurburgring;453326
This is not exactly true. There are msi installers which don't require admin rights to run. Moreover, even if you're the only user of the computer, programs in Vista/7 don't run with admin privileges by default. Try right-click on the msi and select "run as admin".
Tt eSPORTS MEKA G1 | Das S Pro Silent | Leopold FC500RR/AB
All of them full-size. I love my numpad!
Offline Nurburgring
« Reply #9 on: Wed, 16 November 2011, 17:37:03 »
i'm not sure if you know this but you cannot right-click on the msi and select run as admin.
i would have tried that already by now.
thanks for the suggestion though.
is there anyone who experienced this on windows 7 x64 at all?
Offline Nurburgring
« Reply #10 on: Wed, 16 November 2011, 17:54:23 »
good God, this thread is the only existence in the entire google search of this issue...
RIPSTER, do you have experience in this?
Offline Nurburgring
« Reply #11 on: Thu, 17 November 2011, 19:32:27 »
i would appreciate any kind of helpful input on this
« Reply #12 on: Thu, 17 November 2011, 20:17:42 »
It seems to be a general vc++ problem as googling vc80 error 1935 turns up a lot of hits. The fix seems to be running    fsutil resource setautoreset true C:\    in an elevated cmd prompt, rebooting and reinstalling vc++ runtime package, then the dependent software installer.
Offline Alex210
« Reply #13 on: Mon, 26 December 2011, 01:48:26 »
Hi to all,,
This is that type of error which face almost every one in the world and also i was faced this and a lot of finding this solution some of my friend recommend me to use this Error-1935.com and i used this and get all my solution from this site, i recommend you all to use this and get your related fixing error solutions.
Thanks
Offline AlexisSmith077
« Reply #14 on: Thu, 26 January 2012, 05:38:53 »
Its a very irritating error, i also faced this error many times but i fixed it.
Following are the various ways you can implement to fix error 1935
    1. Reinstall Microsoft .NET Framework
    2. Perform a Full Virus Scan
    3. Full Scan your Registry
    4. Reregister Windows Installer
    5. Check System Files for Corruption
    6. Clean the System Junk
The Error 1935 in Windows 7 may still occur if your registry is not properly configured.
If you have already been experiencing the error 1935 error, you can also get some help from this article
ezinearticles.com/?Error-1935-Windows-7---What-Causes-Windows-7-Error-1935,-How-Can-We-Fix-It?&id=5242325
Hope it fix your problem.
Offline fheng
Re: Error 1935 with Cherry Tools on Windows 7?
« Reply #15 on: Wed, 26 September 2012, 14:27:59 »
Same 1925 Error on Windows 7 (64-bit) with 2 different machines.
installed virtually every VC package i could find on microsoft.com
Did a lot of uninstall/reinstall for .Net also
« Reply #16 on: Wed, 26 September 2012, 21:07:34 »
My version of cherry tools works fine in win7 enterprise 64 on my mac pro
Mine is  designer version 5.8.0.5
Welcome to GH!
Depending on your version of W7, you should just be able to run it in XP mode.
Offline SmallFry
« Reply #17 on: Wed, 26 September 2012, 21:29:39 »
Or run as Administrator?
Offline fheng
« Reply #18 on: Thu, 27 September 2012, 06:39:58 »
ran as admin
did 1 - 6 recommended by AlexisSmith077
cherry website says it is supported on win7/64bit
Offline alain
« Reply #19 on: Mon, 17 December 2012, 00:22:03 »
Hi guys,
I'm facing the exact same error as Nurburgring did. Win7 64 Ultimate here, freshly installed.
A confirmed solution would be amazing... :)
