Author Topic: PS/2 to USB for iMac  (Read 1517 times)
Offline nerp
« on: Wed, 16 November 2011, 11:00:48 »
Hey all. Been a while. I'm using my 27" iMac mostly, these days, and would like to use my original Model M instead of my Unicomp Customizer. Does anyone know of a good PS/2 to USB adapter that shouldn't pose too many problems? I do boot into Windows using Boot Camp for Counterstrike:Source so it would be ideal if the board worked both in OSX and Windows. If someone has a link to a known working adapter, I'd greatly appreciate it.
Regards!
U N I.C O M P - Am I the only one that likes the logo?
Offline Input Nirvana
« Reply #1 on: Wed, 16 November 2011, 11:13:12 »
Here
There are at least a few options:
The Blue Cube, you may need a cable extender on the iMac.
 The Y-mouse, allows for 2 PS/2 units to be plugged in and has some features that may be of use since you are on Mac.
Perhaps a couple others.
I use iMac as well.
« Last Edit: Wed, 16 November 2011, 11:18:55 by input nirvana »
Offline kps
« Reply #2 on: Wed, 16 November 2011, 12:38:53 »
I've used this with a Model M on my MacPro3,1.
« Last Edit: Wed, 16 November 2011, 12:42:39 by kps »
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #3 on: Wed, 16 November 2011, 14:40:08 »
With blue cube I had some weird issues - like sending some key codes wrong so the text input was working fine but some system or game shortcuts didn't work.
Also it almost never worked after boot - you had to disconnect and reconnect either keyboard or the adapter. This prevented from using Model M in boot selector (where you have to press option key on boot).
I've recently (a month ago or so) upgraded blue cube to Belkin 2x PS/2 to USB converter and so far I had no issues. As far as I know Belkin is no longer making those adapters but they still show up on eBay and are really cheap - see here:
http://www.ebay.pl/itm/Belkin-USB-PS-2-Adapter-/380383517832?pt=UK_Computing_NetworkCards_RL&hash=item58909fdc88#ht_500wt_922
I'm using it on Mac Pro 5.1 with triple boot to OS X Lion, Ubuntu 11.10 and Windows 7, it works perfectly on all those systems without any additional drivers.
« Last Edit: Wed, 16 November 2011, 14:42:34 by czarek »
Offline nerp
« Reply #4 on: Thu, 17 November 2011, 15:08:47 »
I just ordered the one kps posted a link to. Thanks for the responses, everyone.
