Author Topic: Is a Poker keyboard a good companion for a laptop?  (Read 1714 times)
Offline prpnightmare
« on: Wed, 16 November 2011, 23:51:43 »
I find that my laptop's keyboard isn't all that comfortable to type on, and I find myself making more errors than usual because of it. So, can anyone comment on the Poker's portability and usability?
Offline RColinTaylor
« Reply #1 on: Wed, 16 November 2011, 23:57:08 »
Quote from: prpnightmare;453751
I own a Leopold Tenkeyless and even that I find is fairly portable. Though, at times, I wished I had a Poker or Choc Mini to take with me for writing papers and such at different locations on campus. Think of a Poker as the size of an A4 sheet of paper (give or take some dimensions) and therefore fits fairly well into a backpack alongside a Laptop. For safety, as with a laptop, I would advise a case of some sort (even if its just padding).
Usability wise: I don't really have any experience with the layout of a poker but if you are just doing some regular typing and are not too concerned about using your Function-Row at the same time as your Number-Row I don't see any major issues.
I like my Browns more than my Blues.
Offline rodya
« Reply #2 on: Thu, 17 November 2011, 04:30:33 »
Yes.  It's the smallest Cherry mech.  For constantly moving around with a laptop (e.g. school, cafes) I found it great to use.  Only issue for me was the noise level in public areas; my heavy hands made it definitely noticeable over everyone else's scissor-switch boards.  Leopold/Filco TKL is fine if you're planted in one place, otherwise Poker is definitely lighter and easier to carry.  Layout is a whole other discussion.
Interesting carrying case:  http://geekhack.org/showthread.php?23576-Travel-box-for-Poker-an-interest-check
Offline oneproduct
  • @Ubisoft
« Reply #3 on: Thu, 17 November 2011, 07:08:48 »
It's great for carrying around but as mentioned can be a bit noisy in public areas. I have one with browns that I wanted to use it to take class notes but it was a bit disruptive so I stopped doing that. I still use it when I'm on the move and not in class though, very easy to carry around.
Layout: Colemak
