Author Topic: Who uses a black Realforce Topre at the office?  (Read 1895 times)
Offline Keylamity
« on: Thu, 17 November 2011, 00:24:22 »
Thinking of investing in a the quietude of an "S" version for the office, and considering the black keycaps.  In low lighting folks complain that the text disappears.  Anyone have that same issue at the office, or is that muted grey colour showing up ok?
I hate the thought of having to nose down every time I need to find a number key or something...I have to look to type a number or symbol.
Thanks for any responses.
Offline NormaJean
« Reply #1 on: Thu, 17 November 2011, 00:26:52 »
No problem seeing the letters on the keys at the office. I would use it all the time if I hadn't been stupid and ordered the tkl version :P
Offline kinkng
« Reply #2 on: Thu, 17 November 2011, 06:29:00 »
I'm using a black 86UB at work. I had problems seeing the text on the black keys (same problem at home also). I finally got frustrated enough so that I bought a set of blue keycaps for my white 87U and then used those keycaps on my black 86UB.
IBM SSK - 4
IBM Terminal Mini 1392980 - 2
IBM 1391401 - 12
IBM 42H1292 - 10
IBM Rubber Dome Model Ms - 6
Filco TenkeyLess Blue switches  - 1
Realforce 86U - 2
Realforce 86UB -1
Realforce 87UB 55g -2
Realforce 87U 45g - 1
Realforce 87U Variable Tenth Anniversary - 1
Noppoo Choc Mini Blues - 2
Offline keyboardlover
« Reply #3 on: Thu, 17 November 2011, 13:07:14 »
I used to - great keyboard for the office!
Offline Mazora
« Reply #4 on: Thu, 17 November 2011, 13:20:08 »
Although if you need to look at the keyboard to find your # keys, I think you might wanna go with the white keycaps. I used to have a black HHKB and switched to a white one. Now I have a  white  Realforce. I rarely look at the keyboard...
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline kidchunks
« Reply #5 on: Thu, 17 November 2011, 13:22:37 »
I use a 103 at work and have had no issues seeing the lettering. Just make sure you have some lighting!
Topre || BS > *
my root : kidchunks[dot]com
Offline ownerer
« Reply #6 on: Thu, 17 November 2011, 13:51:07 »
No problems here! the bright fluorescent lighting makes it easy. Can't speak for the old folks here though. Never had a complaint. Then again they didn't complain about my das II either. Dunno.
Offline heliar
« Reply #7 on: Thu, 17 November 2011, 14:02:34 »
ripster, where the keypads from?
Offline ownerer
« Reply #8 on: Fri, 18 November 2011, 08:11:09 »
Quote from: ripster;454186
OLD FOLKS?
Looks down.....
(Attachment Link) 32301[/ATTACH]
Unless you're like 87 going on "retired" I don't think you meet this criterion.
