Author Topic: Issues with Filco TKL Brown and Games  (Read 2105 times)
Offline Notoriousxpinoy
« on: Thu, 17 November 2011, 15:32:07 »
Ive been gaming alot lately and when I press a button alot(Spam) I tend to crash to desktop(Happens alot with World of Warcraft. Anyone having this issue? I tested this with my old G15 keyboard and it doesn't happen at all but it happens alot with the Filco and only the Filco. I don't know whats causing this... Anyone know what can be causing this?
Offline piken
« Reply #1 on: Thu, 17 November 2011, 15:34:23 »
Quote from: Notoriousxpinoy;454263
Easy solution, watch where you have your hand resting. With the g15 you most likely have the game mode switch toggled so your windows key is not dropping you to the desktop. The Filco doesn't have a switch to disable the windows key so it drops you out.
Offline HWI
« Reply #2 on: Thu, 17 November 2011, 15:38:39 »
Is the game actually crashing or does it just minimize it to the desktop?
Bottom Out Like A Boss
Razer BWU | Ducky DK-1087 | Noppoo Choc Mini | CM Storm QFR | KBT Race
« Reply #3 on: Fri, 18 November 2011, 08:25:14 »
Its Crashing to desktop not switching to desktop. It actually crashes the game. Its happening in Skyrim too.... I also went and tested on an older pc of mine and it does the same thing. It usually happens when I press the same key alot(Spamming).
Offline Foodmanchew
« Reply #4 on: Fri, 18 November 2011, 08:48:51 »
I wonder if it's trying to turn on sticky keys or something.
« Reply #5 on: Fri, 18 November 2011, 09:18:38 »
I have sticky keys disabled.
Offline Reptile
« Reply #6 on: Fri, 18 November 2011, 09:22:29 »
Quote from: Foodmanchew;454715
Most likely it is a key combination of some sort that is causing it. If it is actually crashing. Check your windows logs
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline rvrebel
« Reply #7 on: Fri, 18 November 2011, 10:00:33 »
Using ps2 or USB? Try swapping
|| Filco Majestouch 2 || Rosewill RK-9000 || WASD Custom Layout ||
« Reply #8 on: Fri, 18 November 2011, 12:36:27 »
Usb
Offline jbluzb
« Reply #9 on: Thu, 01 December 2011, 07:55:51 »
use ps2
