Author Topic: 'Loose' Topre / HHKB spacebar?  (Read 3234 times)
Offline cheynestoking
    • dischord.org
« on: Fri, 18 November 2011, 04:44:35 »
Hi, long time lurker but first time post - and of course it's with a problem ;)
The spacebar on my relatively new HHKB Pro 2 feels a little loose on one side (the side I hit the most).  There's a little 'give' before the key action actually takes place which makes it noisier and cheapens the feel.
Based on a cursory search through the forum I can't find any similar complaints, but is this something that anyone's come across before?  Is there a fix or is it just a trait of these switches?
-Nick
Offline TDK
« Reply #1 on: Fri, 18 November 2011, 08:15:54 »
Left hand end of the space bar?  If so, mine is the same - it moves about 1mm before meeting resistance.  I've never considered it to be a problem.
Simon.
    • dischord.org
« Reply #2 on: Fri, 18 November 2011, 09:21:42 »
For me it's on the right-hand side.  It's only slight, maybe 1mm's worth of play like you say.
Offline ownerer
« Reply #3 on: Fri, 18 November 2011, 09:21:50 »
Mine's nice and tight, on two Topres. Sounds like a problem to me!
Edit: although mine does wiggle horizontally about 1mm.
Offline RiGS
« Reply #4 on: Fri, 18 November 2011, 09:26:34 »
It's called spacebar rattle. It is not unique to Topre keyboards, pretty common problem with stabilized keys.
Offline tsangan
  • 1000/600
« Reply #5 on: Fri, 18 November 2011, 10:12:43 »
ripster really has hate for these ABS space bars :crazy:
Keyboardless
