Author Topic: Topre Realforce "Silent" keycap replacement?  (Read 3940 times)
Offline dismas
« on: Fri, 18 November 2011, 14:31:49 »
Hi all,
I would like to buy a Topre Realforce "Silent" but it's only available in black from EK. I thought I would just replace the keycaps. Would this work? Or does the silencing mechanism affect the keycaps somehow so I can't replace them? Also are there any sound samples of the silent Realforces? Thanks.
Offline reaper
« Reply #1 on: Fri, 18 November 2011, 15:15:05 »
You shouldn't have any problem switching out the keycaps.  The silencing mechanism is in the switch not the keycaps.  Just pick the color that you like.
Din Eli
Offline pat
« Reply #2 on: Fri, 18 November 2011, 15:26:44 »
I now have two silent 87U's, and I've replaced the keycaps on both and both still sound exactly as they did with the stock black keycaps.
Offline lawlawman
« Reply #3 on: Sat, 19 November 2011, 11:20:36 »
Quote from: dismas;455026
Hi all,
If I were you, I will not buy from EK. I will buy 10th anniversary edition from Leopold. EK is small enough to have no special keyboard tailor-made by Topre.
