Author Topic: Torn on which keyboard to get  (Read 2006 times)
Offline LEGITBALLIN
« on: Sun, 20 November 2011, 10:24:17 »
i live in the us
there are a unch of keyboards i could get but i found these duckys and they are pretty cheap
http://global.pchome.com.tw/?mod=item&func=exhibit&IT_NO=DCAH0X-A50117800&SR_NO=DCAH22&ROWNO=9&tm=u
this one is shipped to me for a bout 80 bucks it has blue switches
does it have any problems anyone have any links to reviews of it?
http://global.pchome.com.tw/?mod=item&func=exhibit&IT_NO=DCAH0X-A58945616&SR_NO=DCAH0X&ROWNO=37&tm=u
this is a green alps type switch ducky it is about 50 bucks shipped to me
i never used green alps switches
are there any problems with this keyboard and are there any reviews of it?
http://global.pchome.com.tw/?mod=item&func=exhibit&IT_NO=DCAH0X-A59130655&SR_NO=DCAH0X&ROWNO=2&tm=u
this one looks like the same as above except with black alps switches
any problems with this one and are there any reviews
also what do the green and black alps switches feel like i've never used them
 and also are there any other good preferably cheap keyboards i should get preferably cherry mx blues or any other switch that is good for starcraft.
OR
http://global.pchome.com.tw/?mod=item&func=exhibit&IT_NO=DCAH28-A58428401&SR_NO=DCAH28&ROWNO=2&tm=u
do i get this i hear its alot better
« Last Edit: Sun, 20 November 2011, 12:34:30 by LEGITBALLIN »
V-tec just kicked in yo\'
« Reply #1 on: Sun, 20 November 2011, 10:30:20 »
Reaper did a review on the ducky 1087 xm. The one with green alps.
Offline LEGITBALLIN
« Reply #2 on: Sun, 20 November 2011, 10:59:00 »
hmm i dont like the sound of the green alps one it sound poorly built im problably gonna get 1087 with blue cherrys are there any known isues with it?
« Reply #3 on: Sun, 20 November 2011, 11:17:20 »
Well, I believe the first 1087s had some quality control issues. Broken mini USB adapters, or ones that would fall off. Uneven spacebars and such. But apparently they have stepped up their quality.
Offline reaper
« Reply #4 on: Sun, 20 November 2011, 11:20:31 »
Well, the XM is pretty loud when you're typing and even more so if you're bottoming out (like I do).  I ended up putting some O-rings on the it and now it's more tolerable.
][/URL]
The black ALPS I believe is linear and the green ALPS is clicky.  I got the clicky one.
Din Eli
« Reply #5 on: Sun, 20 November 2011, 12:01:57 »
Quote from: ripster;456116
Duckys had a quack problem.
I've never seen anybody be specific about this "Problems were fixed" rumor.
Probably started by the OCN sales guys (the moderators there).  Hell, they even close threads if you complain about your Ducky keys fading.
Quack!
I am also interested to see if there's been any real progress in the QC of the ducky's.
Really, what you're saying is that they moved 1984 from fiction to non-fiction over at OCN?
@OP: If you are ordering from PChome anyway, (which is kind-of a hassle) I would recommend getting a CMstorm instead. It might be a bit more, but the quality of mine in excellent.
Offline LEGITBALLIN
« Reply #6 on: Sun, 20 November 2011, 12:33:16 »
WELL if the cm storm is a rebrand of filco ima just get it at 110 shipped i think its a good deal for reds
Offline LEGITBALLIN
« Reply #7 on: Sun, 20 November 2011, 12:34:10 »
someone mentioned its good
