Author Topic: Where else can esc keys go?  (Read 2565 times)
Offline Son of Gnome
« on: Sun, 20 November 2011, 21:43:38 »
Ok guys i got some new key caps but my function row is full and I am wondering where else can else they fit on a keyboard. Thanks!
« Reply #1 on: Sun, 20 November 2011, 21:47:26 »
home/page up cluster. number row and i THINK arrow cluster.
Offline bloodygood
« Reply #2 on: Sun, 20 November 2011, 22:11:40 »
Esc F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Ps/SR ScLk Pa/Br
` 1 2 3 4 5 6 7 8 9 0 - = Ins Home PgUp NmLk / * -
All other keys are sculpted differently i.e different row height shape
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
« Reply #3 on: Sun, 20 November 2011, 22:19:51 »
so they wont fit on the delete end and page down?
Offline bloodygood
« Reply #4 on: Sun, 20 November 2011, 22:20:21 »
Quote from: Son of Gnome;456503
Those are sculpted to match the q w e r t y u i o p [ ] row, sorry man. There are a total of 4 different row shapes for x1.0 keys
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #5 on: Sun, 20 November 2011, 22:21:36 »
They'll fit on any cherry MX switch. It's just a matter of whether or not you want the profile of all the keys in the row to match.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline bloodygood
« Reply #6 on: Sun, 20 November 2011, 22:23:24 »
Quote from: Quarzac;456505
You are right I suppose I should have mentioned that. If you have keys that are non-sculpted i.e all of them have a matching profile, then you can place it anywhere. If you do have sculpted keys then here is your layout.
-keyboard row-  -sculpted row-
row 1 and 2 = key shape row 1
row 3 = key shape row 2
row 4 = key shape row 3
row 5 and 6 = key shape row 4
the numbering starts from the bottom row (your space bar)
« Reply #7 on: Sun, 20 November 2011, 22:28:41 »
k thanks :D
Offline Seriously
  • Filco forever
« Reply #8 on: Mon, 21 November 2011, 02:18:49 »
I can definitely confirm this for Filco keycaps. Using the blank red ESC as my 6 key right now (aids in my finding my hands on the number row faster).
WASD CODE 104 - Filco Majestouch 2 - Filco Majestouch - Filco Majestouch 2 - Realforce 87UW 45G
Reserves: Filco Minila - KBtalking Pure Pro
« Reply #9 on: Mon, 21 November 2011, 03:25:50 »
Clearly the best place for an escape key is the [`~] key
My WYSE doubleshots have an ESC key that went there on the original keyboard, and I put it there on my current one, because the colour theme matched. It's still mapped to [`~] though :p Since it's QWERTY, I almost never use it.
I put my (cherry profile?) shamrock keycap on my [Delete] key for colour-reasons, and because the profile matches the rest of the keys in that area better.
Offline bloodygood
« Reply #10 on: Mon, 21 November 2011, 09:57:39 »
Quote from: dorkvader;456609
Wow I just now realized that the shamrock keycap is row 3 keycap.. the more you know. But the thread said it was a "Row 1" which they meant "Row 4" but either way they were wrong in both accounts haha.
« Last Edit: Mon, 21 November 2011, 10:01:54 by bloodygood »
« Reply #11 on: Mon, 21 November 2011, 22:08:26 »
Quote from: bloodygood;456719
It's a function row-sized cherry profile, which is coincidentally very close to the 'tab' row on filco/WASD/etc keycaps.
So just remember that SP row1 ~ filco row2. This is because SP caps are generally shorter.
Offline BiNiaRiS
« Reply #12 on: Tue, 22 November 2011, 00:55:14 »
Take off the spacebar and put an Esc key there. You'll need to practice making sure you aim right though.
KMAC 2 w/ErgoClears
