Author Topic: Where can I get a DCS family caps-lock...  (Read 6361 times)
Offline bavman
« on: Mon, 21 November 2011, 22:27:28 »
key that will fit on a filco?
Offline zoidbergslo
« Reply #1 on: Tue, 22 November 2011, 01:10:21 »
DCS (from SP) has lower profile than Filco's original key caps. Maybe WASD has same profile as Filco.
Filco Tenkeyless
Offline itlnstln
« Reply #2 on: Tue, 22 November 2011, 04:14:52 »
Quote from: zoidbergslo;457223
This is the case.  Be careful going to WASD.  You might end up with a few sets of caps and a keyboard to boot.
Offline bavman
« Reply #3 on: Tue, 22 November 2011, 09:23:56 »
I'm actually trying to find a DCS because im replacing the original caps on my filco with double shots from a cherry board. I already got all the other keys that are incompatible, i just need the caps lock key because the one from the cherry boards has the stem in a different place so it wont fit on the filco. I emailed Mellisa at SP but she told me she didn't have blank ones in stock...then tried to make me pay $100 so i can get a blank cap manufactured.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #4 on: Tue, 22 November 2011, 15:17:08 »
Quote from: bavman;457364
If you cant find a key I may be able to mod your current one for you.
Offline bavman
« Reply #5 on: Tue, 22 November 2011, 16:37:07 »
Quote from: TheProfosist;457653
I would but I dont know if you'd be able to do a stepped key. Heres a couple pics i just took. [ Attachment Invalid Or Does Not Exist ] 32714[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 32715[/ATTACH]
« Reply #6 on: Tue, 22 November 2011, 16:38:19 »
Quote from: bavman;457731
I would but I dont know if you'd be able to do a stepped key. Heres a couple pics i just took. (Attachment Link) 32714[/ATTACH] (Attachment Link) 32715[/ATTACH]
Could you take a pic with a regular caps lock aligned right below it?
Offline bavman
« Reply #7 on: Tue, 22 November 2011, 17:12:43 »
[ Attachment Invalid Or Does Not Exist ] 32719[/ATTACH]
The quality isnt that great but thats the best i could get with my phone.
« Reply #8 on: Tue, 22 November 2011, 17:17:54 »
yes I could mod that but I would have to remove the original stem to make it work.
