Author Topic: what keycaps for my poker?  (Read 1660 times)
Offline ajx
« on: Tue, 22 November 2011, 19:03:52 »
hi, i m still undecided to choose suitable keycaps for my kbc poker
as lettering from wasd keys are fading gradually, i m willing to buy a set of keycaps
after some research, i found eventually those types of keycaps:
- PBT, white, engraved
- PBT, white, laser etched
- ABS, white, engraved
- ABS, white, laser etched
wich one do you prefer?
Offline tsangan
  • 1000/600
« Reply #1 on: Tue, 22 November 2011, 19:07:44 »
PBT>ABS, if you want ABS why not just stick with the ones it came stock?
PBT feels more solid and takes a while longer to get the shine on it, overall I like the feel of PBT a lot more then ABS
Keyboardless
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Tue, 22 November 2011, 19:42:50 »
PBT Engraved or soon you should be able to get custom caps from WASD.
Offline Gegs
« Reply #3 on: Sun, 18 December 2011, 09:56:33 »
Is the KBC Poker compatible with ANY cherry keycap? If it's not, what keycaps is it compatible with? I am also interested in purchasing some PBT keycaps for this board however I do not know which ones will fit perfectly.
« Last Edit: Sun, 18 December 2011, 19:08:47 by Gegs »
Offline Gegs
« Reply #4 on: Sun, 18 December 2011, 19:11:26 »
Read it already. Best mention you made in your wiki was that a filco spacebar fit. My question stands unless it's been answered elsewhere in which case a link would be fantastic.
