Author Topic: Cheapest place to buy keycaps?  (Read 4382 times)
Offline roadlesstraveled
« on: Fri, 25 November 2011, 12:24:51 »
I'm looking to purchase white engraved or side printed PBT keycaps and possibly clear ABS keycaps (I don't believe they make clear PBT keycaps, or am I wrong?).
Where's the cheapest place to buy them?
Offline VPX
« Reply #1 on: Fri, 25 November 2011, 12:40:23 »
I don't think there are clear ABS key caps. They are made of Polyacryl, that's why they are so hard and brittle, not a good material for key caps (if you ever used BIC Cristal pens you know why).
Edit: Sorry the Cristal Pen ist made of Polystyrene not Polyacryl, which is even worse I think.
« Last Edit: Fri, 25 November 2011, 12:50:56 by VPX »
Hack Amethyst 3000 key cap set coming when it\'s done (2012)
« Reply #2 on: Fri, 25 November 2011, 16:39:33 »
Quote from: VPX;458965
IS polyacryl another name fro PMMA or acrlyic, or is it PAA "polyacrylic acid" I can't keep up with all these stupid trade names fro plastics.
Also, I suspect the clear keycaps are ABS.
Offline VPX
« Reply #3 on: Fri, 25 November 2011, 17:13:22 »
Quote from: dorkvader;459039
Just a generic term for different acrylics, but it is definitely PMMA.
