Author Topic: Keyboard prevents S3 sleep on PC  (Read 1242 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
« on: Fri, 25 November 2011, 12:27:08 »
My Poker blue is apparently preventing the PC from entering S3 sleep. It does the same on 2 systems. The keyboard appears to function correctly as it outputs the correct scan codes etc on all keys. However on one system there is a bios error regarding the keyboard on boot, and both systems list it a a problem device in msinfo.
Has anyone seen this behavior? I am curious to what is causing it and if there is anything I can do to correct it.
