Author Topic: Round three double shots and Filco tenkeyless  (Read 1270 times)
Offline kinkng
« on: Sat, 26 November 2011, 21:02:11 »
Well, I finally got around to changing the key caps on my Filco tenkeyless with blue switches with the round three group buy doubleshots. However, when I installed the new ones, the Caps Lock and left Shift key seems to be too close to the left side of the case and it sticks a little. The keys still register but when I press on it, it is not smooth and it does not seem to pop back all the way up. Has anyone else run into this issue?
IBM SSK - 4
IBM Terminal Mini 1392980 - 2
IBM 1391401 - 12
IBM 42H1292 - 10
IBM Rubber Dome Model Ms - 6
Filco TenkeyLess Blue switches  - 1
Realforce 86U - 2
Realforce 86UB -1
Realforce 87UB 55g -2
Realforce 87U 45g - 1
Realforce 87U Variable Tenth Anniversary - 1
Noppoo Choc Mini Blues - 2
Offline whiskerBox
« Reply #1 on: Sat, 26 November 2011, 21:38:14 »
I ran into this same issue with the rgb set, I just ran a Dremel along the bottom edge and now it works fine and you can't see where I dremeled it either I will post pics on Tuesday when I am back in town
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
