Author Topic: Leopold FC200R backspace key  (Read 2835 times)
Offline makuab
« on: Sat, 26 November 2011, 21:14:07 »
I remove the leopold FC200R backspace key because it was squeaking, however now i'm not sure if i've put it back on correctly, it looks slightly more elevated than the other keys. Help please?
Offline DaemonRaccoon
« Reply #1 on: Sat, 26 November 2011, 21:18:55 »
Push down harder.
The Cherry stabilizers (or clones if the rumors are true) have that problem.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline makuab
« Reply #2 on: Sat, 26 November 2011, 21:20:41 »
how hard? I don't want to break it.
Offline makuab
« Reply #3 on: Sat, 26 November 2011, 21:22:11 »
also how can I tell if the stabilizers are in their places?
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #4 on: Sat, 26 November 2011, 22:09:39 »
Post a picture.
Offline makuab
« Reply #5 on: Sat, 26 November 2011, 22:13:48 »
yeah it definitely looks off
still squeaking too D:
« Reply #6 on: Sat, 26 November 2011, 22:25:13 »
Make sure the stabilizers are aligned with the stems. And just press down until you bottom out
Offline makuab
« Reply #7 on: Sat, 26 November 2011, 22:26:53 »
Quote from: demik;459436
that's my problem, they seem to be kind of hard to align
« Reply #8 on: Sat, 26 November 2011, 22:34:38 »
Try aligning one side first then middle then other side. Works for me.
Offline makuab
« Reply #9 on: Sat, 26 November 2011, 22:39:02 »
okay. How can I tell if it's aligned?
Offline pitashen
« Reply #10 on: Sat, 26 November 2011, 23:43:22 »
well... if you can push the key down smoothly with some increased force. Then it should mean that it is aligned...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #11 on: Sun, 27 November 2011, 15:35:36 »
I am going to guess you dislodged the stabilizer mount. I did that once on my Leopold which caused the key to sit oddly like that. It clips into the pcb, but the problem is it is under the plate so it can be hard to see. With the keycap off, can you move the stabilizer towards the fkeys or enter? If so you are going to need something quite small to use to press the clips back into the pcb.
Offline makuab
« Reply #12 on: Sun, 27 November 2011, 19:20:31 »
Quote from: lysol;459665
I think it might be okay.
Offline makuab
« Reply #13 on: Sun, 27 November 2011, 19:50:58 »
Quote from: ripster;459785
If I was Sixty I'd blame clone stabilizers.  See The RipTheCompetition Effect.
I don't understand.
Did I make a bad choice with this keyboard?
Offline makuab
« Reply #14 on: Sun, 27 November 2011, 20:31:01 »
Quote from: ripster;459816
I'm just kidding about that clone thing.
Check the key for molding crud in the cruciform holes.  There's not  a lot of variables here.
I think it might be okay. The key can be compressed completely and doesn't feel awkward or anything, it does look slightly higher than the number row, is that normal?
EDIT: Nevermind, it's definitely abnormal.
Offline makuab
« Reply #15 on: Sun, 27 November 2011, 21:36:52 »
I think I fixed it by pressing down really hard
Offline pitashen
« Reply #16 on: Sun, 27 November 2011, 21:58:34 »
Quote from: makuab;459800
It is not a bad choice. I own a second hand one and I like it a lot.
Do you still have your key sticking out? If it is fixed, just enjoy the keyboard.
Offline makuab
« Reply #17 on: Sun, 27 November 2011, 21:59:59 »
I can't tell, the bottom seems to be aligned with the rest of the keys, so I think I might be okay.
