Author Topic: [Ebay.com] Keytronic Oct. 1983  (Read 2836 times)
Offline rodtang
« on: Sun, 27 November 2011, 11:19:31 »
This seems to be a good deal.
« Reply #1 on: Sun, 27 November 2011, 16:51:07 »
what is that? looks like a model c.
should weigh a ton.
edit: from the fcc id, it might be a keytronic?
http://geekhack.org/showthread.php?10597-Key-Tronic-boards/page3
« Last Edit: Sun, 27 November 2011, 16:56:25 by dorkvader »
Offline rodtang
« Reply #2 on: Sun, 27 November 2011, 17:45:21 »
Quote from: dorkvader;459721
Well, the title of both this thread and the ebay says Keytronic so, nice job Sherlock.
Offline rodtang
« Reply #3 on: Mon, 28 November 2011, 06:19:52 »
This is probably a better deal, at least for UK'ers
« Last Edit: Mon, 28 November 2011, 09:09:49 by rodtang »
Offline 7bit
  • MX1A-G1DW
« Reply #4 on: Mon, 28 November 2011, 06:41:49 »
Quote from: ripster;459758
Foam/Foil capacitive.
(Attachment Link) 33091[/ATTACH]
Elementary, My Dear Watson.
Mine looks much better (and is even older!):
« Last Edit: Mon, 28 November 2011, 07:11:19 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline rodtang
« Reply #5 on: Mon, 28 November 2011, 09:12:08 »
Quote from: 7bit;459961
This one looks better but is most likely newer.
Offline 7bit
  • MX1A-G1DW
« Reply #6 on: Mon, 28 November 2011, 09:47:53 »
Quote from: rodtang;459994
Nothing against NIB, but I like the look with those single width keys more.
Also, it might come with rubber-dampers instead of real-springs.
