Author Topic: Just got a leopold FC200R, What do I do to make sure everything is in order?  (Read 1084 times)
Offline makuab
I just want to make sure everything is working properly, what steps should one take after just purchasing a new mechanical keyboard?
Offline ZeroGraVT
« Reply #1 on: Sun, 27 November 2011, 19:28:01 »
type on it.
Offline makuab
« Reply #2 on: Sun, 27 November 2011, 19:47:43 »
Quote from: ZeroGraVT;459789
type on it.
haha good advice, I suppose.
Offline pitashen
« Reply #3 on: Sun, 27 November 2011, 19:51:50 »
download aqua's keytest app and type all the keys. If they all registered by the key press, then you are good to go.
EDIT: did i just repeat what rip said?... oops. Oh also, listen for the "ping" noise coming from the keyboard when typing. If it pings, its defective.
EDIT2: OK I take that back, don't listen for the "ping" sound. It was meant to be a mean prank. Just make sure it performs in KeyTest app.
« Last Edit: Sun, 27 November 2011, 20:04:32 by pitashen »
