Author Topic: Do replacement keycaps exist in this height?  (Read 4821 times)
Offline BossBorot
« on: Sun, 27 November 2011, 19:38:05 »
I am a new member here but have been through a ton of wiki and thread posts on keycaps with the aim to get a set for both my Filco brown ten keyless and Filco FKBT22MB, I added the model number in case someone searches for it later like I did before posting, brown bluetooth keypad.
However the top row of keys on the keypad are much taller then any key off of my ten keyless board.
The keypad works fine with keys the height of the escape key off of the ten keyless board but if possible I would prefer to get a similar height key. I doubt it is possible but if anyone knows it's you guys.
I am trying to attach an image but for some reason it won't let me post the thread if I use image tags and I see no option to attach.
so apparently I can't add images :( the file I was trying to attach is at imgur and is /AdIE0.jpg after the site address.
« Reply #1 on: Mon, 28 November 2011, 18:48:52 »
http://i.imgur.com//AdIE0.jpg
Link to picture. It's keycaps.
Offline BossBorot
« Reply #2 on: Tue, 29 November 2011, 14:26:03 »
thank you for posting the link
Offline laffindude
« Reply #3 on: Tue, 29 November 2011, 17:54:19 »
R5 keys rear its ugly head again. Say no to R5.
Offline tsangan
  • 1000/600
« Reply #4 on: Tue, 29 November 2011, 17:54:51 »
Those high spherical are awesome, I NEED MOAR!
Next GeekHack key should be spherical!!
Keyboardless
