Author Topic: Possibly any help with keycaps?  (Read 4021 times)
Offline logisticsqt
« on: Tue, 29 November 2011, 19:54:23 »
Hi, I'm a complete idiot about this and I am buying a Ducky keyboard for the customization factor. I would like to make my keyboard colorful like the first picture you get if you google "ducky keyboard" (I can't link it). I don't really care exactly what type they are, I would just like some basic, colorful keycaps, I'm having trouble finding them. Thanks to anyone that helps!
Edit: I have found the wasd caps after like two hours of searching. I was going to customize my own for $50, does anyone know of any better deals? Blank is fine.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Tue, 29 November 2011, 20:16:22 »
I think what you are after are the KBC 'Rainbow' set. Ask imsto or qtan who are members here about them. Prices usually are between $20-35 for rainbow sets depending on plastic material.
Offline whiskerBox
« Reply #2 on: Tue, 29 November 2011, 20:20:56 »
They are also readily available on ebay, but if you can go through someone on GH you will get a better deal for sure. Some of the caps offered on ebay are really cheap and not exactly as pictured so buyer beware
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
