Author Topic: What is the difference between the Blackwidow and the Blackwidow-Mac version?  (Read 2729 times)
Offline mouse.the.lucky.dog
Is it just the software included? I have to say that I find any description of a keyboard saying a certain OS is required a bit confusing.
Don't the basic functionality of all keyboards work on all OSes?
Offline N8N
« Reply #1 on: Thu, 01 December 2011, 19:55:47 »
yes, but traditionally mac keyboards have had control-option-command keys instead of control-win-alt.  Compare and contrast
http://en.wikipedia.org/wiki/File:Apple_Extended_Keyboard.jpg
http://upload.wikimedia.org/wikipedia/commons/7/79/Unicomp_keyboard.jpg
notice that the numpad is a little weird on the Apple keyboard as well.  They like to be different!  (I don't know if the Razer goes so far as to make that change, or just changes the printing on the bottom row keys to be Mac friendly.)
« Reply #2 on: Thu, 01 December 2011, 20:38:31 »
Oops. Forgot about that. Is it just  the keycaps or is there a different signal sent to the computer with the option/windows key? Or is it just the keycap? ( Nevermind the menu button. I never use that. )
Offline FourOhFour
« Reply #3 on: Sat, 03 December 2011, 20:01:53 »
The command key (cloverleaf or Apple symbols) should work as the Windows key, and option will work as alt. These aren't in the positions a Windows user expects (Win and Alt need to be swapped), but it'll work. Clear (on the numpad) might work as numlock (or might not; I can't remember). Delete (in the backspace position) will work as backspace, and forward delete (in the delete position) as delete. The fkeys should work, with F13-F15 working as print screen, scroll lock, and pause/break. Older Mac keyboards have a help key above fwd del, which will work as insert.
Looking at that particular keyboard, F15 is missing so you won't have pause/break and you probably won't have insert since fn is in that position. There is a key where the Menu key would be on a PC keyboard, but I don't know what it does.
Personally, unless you are using Mac OS almost all of the time, I'd buy the standard version. It'll work fine on a Mac, unless they're doing something stupid. (hold F12 for eject; print screen, scroll lk, and pause/break become F13-F15; num lock becomes clear; insert does nothing useful and menu does nothing at all; windows becomes command and alt becomes option (but again, in the wrong order; they can easily be swapped in Sys Prefs -> Keyboard -> Modifier Keys))
