Author Topic: Buying Cherry MY8000 for keycaps for Filco?  (Read 3286 times)
Offline shawn o
« on: Sat, 03 December 2011, 21:50:07 »
Would all the keycaps from the auction below fit on a Filco? I assumed they would but was reading and saw mention of an offset capslock and lower keys? Does that mean the stem on some of the keys is offset?
http://www.ebay.com/itm/Cherry-MY8000-Keyboard-Card-Reader-S0526-/180767292486?pt=PCA_Mice_Trackballs&hash=item2a1691fc46
« Reply #1 on: Sat, 03 December 2011, 21:56:45 »
if you're looking for double shots...
those aren't it
Offline shawn o
« Reply #2 on: Sun, 04 December 2011, 04:11:49 »
No, don't like double shots. Prefer the laser ones.
Offline N8N
« Reply #3 on: Sun, 04 December 2011, 05:26:00 »
I would assume that the stems are offset on caps lock and the bottom row as a similar boards w/ doubleshots is that way.  It's workable with a little epoxy...
Offline slueth
« Reply #4 on: Sun, 04 December 2011, 06:28:08 »
Why wouldn't you like the doubleshots one and prefer the lasered ones?
Offline N8N
« Reply #5 on: Sun, 04 December 2011, 06:44:31 »
I'm not the OP, but I ASSume feel.  the doubleshots look sexy, but they are ABS while the lasered ones are PBT.
Offline Clickey
« Reply #6 on: Sun, 04 December 2011, 14:08:58 »
Quote from: N8N;463821
This, I have a set of lasered cherry keycaps that are more compatible for less $ if you want.
"we are on Geekhack not Lazy****" - The Solutor
Offline shawn o
« Reply #7 on: Sun, 04 December 2011, 16:14:44 »
Same colors?
Online Findecanor
« Reply #8 on: Sun, 04 December 2011, 16:57:52 »
Black lasered Cherry keys are POM. White/grey/beige Cherry keys are PBT.
It is not only the offset keys that are incompatible with Cherry MX. All wide keys on a Cherry MY keyboards are too.
You can read more in this guide.
Offline Clickey
« Reply #9 on: Sun, 04 December 2011, 19:22:32 »
Same colors
Quote from: Findecanor;464069
Wide keys?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Sun, 04 December 2011, 19:36:09 »
Ok... the stabilized keys. I'd never seen Cherry keys with the stabs molded in like that, odd. Won't be a problem on the older ones though.
Offline pitashen
« Reply #11 on: Sun, 04 December 2011, 20:03:40 »
Quote from: lysol;464156
Not entirely correct still. Here are the keys from G81 that will not fit filco compatibles and leopold:
Caps lock (also applies to g80 with stepped caps lock)
Ctrl
Alt
Win
Menu
Space bar (applies to all cherry boards)
The rest WILL fit.
« Last Edit: Sun, 04 December 2011, 20:25:05 by pitashen »
« Reply #12 on: Sun, 04 December 2011, 20:47:43 »
Oh, I knew about the capslock and bottom row. I harvested most of my doubleshots from g81's. I'd just never seen the shifts, enter, backspace not compatible either. Since I was specifically talking about stabilized keys my statement was in fact correct.
« Last Edit: Sun, 04 December 2011, 20:49:59 by lysol »
Offline pitashen
« Reply #13 on: Sun, 04 December 2011, 20:54:08 »
Quote from: lysol;464190
ya...my brain is not working right these couple of days..
Anyway, to OP,
Get Clickey's set would be the safest option for you. If I am not mistaken, only the spacebar and the enter as well as the backslash won't fit out of the entire set. Thats 3 keys not fitting as compare to the potentially 9 keys if you get the MY8000.
Or you could for the enter key and the backslash sake get that ebay deal as well... to make everything complete.
« Last Edit: Sun, 04 December 2011, 21:31:39 by pitashen »
