Author Topic: [WTS] IBM Model M 1989 - ps/2 cable  (Read 6981 times)
Offline paradox
  • Trade Count: (0)
« on: Wed, 07 December 2011, 16:09:33 »
SELLING:
I'd prefer to ship within the US if possible.
IBM MODEL M, buckling springs - Good/Great condition no stains or damage - 60$ shipped
CM Storm Tenkeyless, w/Browns - This is the gray matte version with no brands/logos except for on the back of the keyboard (behind the function keys), I've owned it for 1-2 years but the keys have seen little to no use since I swapped them out right shortly after I purchased the board for some other keys, corners of case show some wear - 60$ shipped - sold
****Keyboard will come with the original keys, not the keys pictured
Proof of Ownership Pics:
Leopold Tenkeyless Otaku White, Cherry Red - 70$ - SOLD
Filco Majestouch 104 key, Cherry Brown - 70$ - SOLD
Matias TactilePro FK302 - Apple USB keyboard, works with Windows - 50$ - SOLD
Mod Edit: Removed moderation note prior to approval.
« Last Edit: Sat, 14 November 2015, 12:13:21 by paradox »
Offline hazeluff
  • Trade Count: (0)
  • 光復香港
    • Hazeluff
Mini Choc, black - MX Blue - Repaired and Working
« Reply #1 on: Wed, 07 December 2011, 16:12:44 »
Have you tried uninstalling the device drivers?
I don't think it's dead.
Fight For Freedom. Stand with Hong Kongers
Offline paradox
  • Trade Count: (0)
« Reply #2 on: Wed, 07 December 2011, 16:22:12 »
It was plug and play and working fine until now.  I don't see any drivers for this board on Google.  I also use an adapter to connect with PS2 with no luck.
Offline alaricljs
  • I be WOT'ing all day...
  • Trade Count: (0)
« Reply #3 on: Wed, 07 December 2011, 16:23:16 »
So how much?
Filco w/ Imsto thick PBT
Offline bloodygood
  • Trade Count: (0)
« Reply #4 on: Wed, 07 December 2011, 17:52:05 »
I would recommend first asking if another member on the forums would be willing to take a look at it for cost of shipping only. Then maybe you won't need to get a new keyboard since the Mini is still a good board and it seems highly unlikely it would fail so catastrophically so quickly.
Also. Covered by warranty?
Current collection: Filco Tenkeyless MX Brown, IBM Model M, Happy Hacking Keyboard Lite II, Dell AT101W.
Looking for: IBM Model M SpaceSaver, HHKB Topre keychain. >> Feedback Thread
  • Trade Count: (0)
« Reply #5 on: Wed, 07 December 2011, 17:56:15 »
I'm having the same problem with my leopold. Keeps disconnecting every 2-3 mins under USB. Luckily, I haven't had problems under ps/2.
Offline hazeluff
  • Trade Count: (0)
  • 光復香港
    • Hazeluff
« Reply #6 on: Wed, 07 December 2011, 18:02:40 »
Quote from: paradox;466048
I'm not talking about a specific driver for it. When you plug and play, windows installs a driver so that it will run with. Sometimes devices just need that driver reinstalled.
Code: [Select]
[h=4]Step 3: Manually reinstall the drivers[/h][COLOR=#000000][FONT=Segoe UI]To remove and then reinstall the drivers, follow these steps:[/FONT][/COLOR][LIST=1|INDENT=1]
[*]Disconnect the device from the computer.
[*]Turn off the power for the device, if the device has a separate power supply.
[*]Open Device Manager. To do this, use one of the following methods:[LIST=|INDENT=1]
[*]In Windows Vista or Windows 7, click [B]Start[/B]
[IMG]http://support.microsoft.com/library/images/support/kbgraphics/Public/EN-US/VistaStartButton.jpg[/IMG]
, type [B]device[/B] in the [B]Start Search[/B] box, and then click [B]Device Manager[/B] in the [B]Programs[/B] list. If you are prompted for an administrator password or for a confirmation, type the password, or click [B]Allow[/B].
[*]In Windows XP, click [B]Start[/B], click [B]Run[/B], type [B]devmgmt.msc[/B], and then click [B]OK[/B].
[/LIST]
[*]Double-click [B]Keyboard[/B], right-click the keyboard that you use, and then click [B]Uninstall[/B].
[B]Note[/B] If your device is not listed, this means that the device was removed automatically when you disconnected the device. Go to the next step.
[*]Restart the computer.
[*]First, turn on the device, if you have to, and then plug the device into the computer. Your computer detects the device and then reinstalls the drivers for the device.
[/LIST]
I'm only bringing this up since I don't think something fails that easily. Have you tried it on another PC? Maybe the cable is damaged?
Offline paradox
  • Trade Count: (0)
« Reply #7 on: Wed, 07 December 2011, 18:46:33 »
new information on the problem, see original post for details
Offline alaricljs
  • Trade Count: (0)
« Reply #8 on: Wed, 07 December 2011, 18:58:11 »
Are you using a USB hub at all?  In my case it wasn't the Filco I had that was flaking out it was the hub it got plugged into overheating and freaking out.
Also you might want to try a different port or PC... could still the other end of the cable causing the problem.
Offline paradox
  • Trade Count: (0)
« Reply #9 on: Wed, 07 December 2011, 19:58:25 »
Quote from: alaricljs;466155
Yes.  Tried different ports.  Tried different PCs.  Problem is always the same.  Keyboard will only work for about a minute and then it needs a few minutes of rest to "cool down" (see edit in original post).
It's directly connected to my PC no hub etc.  As mentioned earlier I tried it on the PS2.
On top of all of this information the PC was working fine for 3 weeks so I'm not sure why it would suddenly quit if it was a driver issue.
Offline alaricljs
  • Trade Count: (0)
« Reply #10 on: Wed, 07 December 2011, 20:05:02 »
Quote from: paradox;466196
That I can answer - Windows Update.
Offline paradox
  • Trade Count: (0)
« Reply #11 on: Wed, 07 December 2011, 20:55:01 »
Quote from: alaricljs;466203
It would if I did an update.  That still wouldn't explain why it doesn't work on other computers running Windows XP (mine is Windows 7).
Offline hazeluff
  • Trade Count: (0)
  • 光復香港
    • Hazeluff
« Reply #12 on: Wed, 07 December 2011, 21:03:24 »
Lol. I hate windows updates... possibly can be because of it.
@OP
If you open up the case of your keyboard and feel the microcontroller, is it physically hot? Maybe a short somewhere, pulling a lot of current (hence overheating). I totally want to fix it...@_@
I'd try and get warranty if that's still valid for you. Reselling it may get you a bit back. I'm kind of interested actually. Only if you are UK and offering for cheap (and I mean real cheap...). ><. Otherwise someone will want to pick it up; For the case/switches/keycaps.
Offline paradox
  • Trade Count: (0)
« Reply #13 on: Wed, 07 December 2011, 23:57:04 »
Unfortunately I'm in the US.  I bought this from Qtan on eBay.  His return policies only support DOA items.  Looking around the site it seems other people got a warranty card with theirs.  I'll have to track mine down I guess.
Quote from: hazeluff;466236
@OP
Offline hazeluff
  • Trade Count: (0)
  • 光復香港
    • Hazeluff
« Reply #14 on: Wed, 07 December 2011, 23:58:41 »
Quote from: paradox;466317
So sorry for your loss.
I got mien from him too. Mine's still alive and kicking. I bring it around a lot and it still hasn't died. = (
GLWS
Offline bloodygood
  • Trade Count: (0)
« Reply #15 on: Thu, 08 December 2011, 01:07:31 »
If for whatever reason it goes to just be a "harvest for parts" price, I would be interested. But I think odds are it will either be purchased as a fixer up or someone will help you fix it yourself.
Offline paradox
  • Trade Count: (0)
« Reply #16 on: Thu, 08 December 2011, 09:33:27 »
New details.  Edited thread title.  Added a price.
Offline paradox
  • Trade Count: (0)
bump, keyboards for sale
Offline paradox
  • Trade Count: (0)
Edited with a price drop on all three keyboards.
Offline Capitalistix
  • Trade Count: (0)
  • Cherry MX Green Disciple
    • Uncanny Electronics
What kind of switches does that Tactile Pro have?
Offline paradox
  • Trade Count: (0)
I believe it has white alps, they are clicky.  You can probably find some examples of them in action on Youtube.
Offline jabar
  • Trade Count: (0)
These are some very nice prices. Too bad I have earmarked everything I plan on spending (and then some).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline daerid
  • Trade Count: (0)
    • Rossipedia
YGPM regarding Tactile Pro
Offline daerid
  • Trade Count: (0)
    • Rossipedia
Payment sent for TP
Offline babyhands
  • Trade Count: (0)
Re: [FS] Price Drop-- Leopold Otaku Tenkeyless Cherry MX Red
« Reply #24 on: Sun, 27 January 2013, 21:48:46 »
PMing you about leopold
Offline paradox
  • Trade Count: (0)
Re: [WTB] Leopold FC660M MX Blue
« Reply #25 on: Sun, 03 August 2014, 16:22:28 »
Bump, looking to buy a new item
Offline slip84
  • Trade Count: (0)
  • GUYDUDE MAGICIAN
« Reply #26 on: Sun, 03 August 2014, 17:46:51 »
I have a buddy with one with dyesub caps and blue switches. What are you looking to spend? I'll have to reach out to him. He's not on GH. Hit me with a PM if you wanna deal.
Offline paradox
  • Trade Count: (0)
Re: [WTB] RGBY Modifiers w/ white text
« Reply #27 on: Fri, 08 August 2014, 21:34:47 »
bump - looking for keys
Offline paradox
  • Trade Count: (0)
Re: [WTB] Poker or similar with Reds/Blacks, Cherry MX Green keyboard
« Reply #28 on: Sat, 06 June 2015, 18:34:56 »
bump
Offline heedpantsnow
  • Trade Count: (1)
  • Old enough to know better
« Reply #29 on: Sat, 06 June 2015, 23:11:34 »
I have a Poker X, all stock and mint, with reds I think. PM me if interested.
I'm back.
Offline paradox
  • Trade Count: (0)
Re: [WTS] IBM Model M and CM Storm TKL Browns
« Reply #30 on: Sun, 02 August 2015, 23:29:43 »
bump
Offline mashingkeys
  • Trade Count: (0)
« Reply #31 on: Mon, 03 August 2015, 10:04:02 »
Wait..  is that CM Storm still sitting around..?
Offline paradox
  • Trade Count: (0)
« Reply #32 on: Mon, 10 August 2015, 17:33:38 »
bump
Offline paradox
  • Trade Count: (0)
« Reply #33 on: Fri, 21 August 2015, 16:56:39 »
bump
Offline paradox
  • Trade Count: (0)
« Reply #34 on: Sun, 30 August 2015, 23:49:49 »
bump, proof of ownership pics added
Offline paradox
  • Trade Count: (0)
« Reply #35 on: Wed, 09 September 2015, 15:24:03 »
bump
Offline soaps42
  • Trade Count: (0)
« Reply #36 on: Wed, 09 September 2015, 19:36:30 »
Pming!
Offline yomammary
  • Trade Count: (0)
« Reply #37 on: Thu, 10 September 2015, 07:27:42 »
Is the Model M bolt modded?
RF 87u 55g | Leeku 1800
Offline paradox
  • Trade Count: (0)
Re: [WTS] IBM Model M 1989 - ps/2 cable
« Reply #38 on: Sat, 14 November 2015, 12:13:40 »
Bump
Offline linkshine
  • Trade Count: (0)
  • If you wanna b my lover, u gotta get w/ my friends
« Reply #39 on: Sat, 14 November 2015, 14:12:53 »
PMed for Model M!
Offline SamirD
  • Trade Count: (0)
« Reply #40 on: Thu, 19 November 2015, 23:13:30 »
Sold the M?
