Author Topic: Cherry reds?  (Read 4579 times)
Offline aynjell
Cherry reds?
« on: Thu, 08 December 2011, 14:35:53 »
Das Keyboard Professional -mx blue- @ Work
Das Keyboard S Ultimate Silent -mx brown- @ Home
Do not fart in the same room as a dark brother or sister, to do so is to invoke the wrath of Sithis...
Offline F u r u y á
Cherry reds?
« Reply #1 on: Thu, 08 December 2011, 15:33:31 »
I'd go for Rosewill because of the stabilizers.
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline drsauced
Cherry reds?
« Reply #2 on: Thu, 08 December 2011, 15:39:46 »
I'd go Rosewill because of the spacebar.
Filco Ninja 104 Tactile w/Imsto PBT caps | Deck Legend Ice Linear | FC200RT Clear w/Danger Zone | Topre 87U 45g EK | '89 & '93 1391401 | Ping is Life
Cherry reds?
« Reply #3 on: Thu, 08 December 2011, 15:49:13 »
I was facing this dilemma, but I bought the Leopold because the Rosewill logo is just so big and ugly.
Maybe I made a mistake, I have not used it yet, but they should really not try so hard !
- Oliver Willis 2026-08-01
Offline bienc
Cherry reds?
« Reply #4 on: Thu, 08 December 2011, 16:07:01 »
I went with a Rosewill because of the price ($10 less than Leopold if you get it now with free shipping) and the stabilizers I hear are "better" than the Leopolds. I would have gone for Leopold Otaku otherwise.
| Rosewill RK-9000RE |
Offline Gerk
Cherry reds?
« Reply #5 on: Thu, 08 December 2011, 21:14:18 »
My Rosewill with reds is ping free.
Rosewill RK-9000RE (reds) | Das Keyboard Model S Professional Silent (browns) | Leopold TKL (browns) | F21-7D "Mechanical Keyboard" (Blue Alps) | Filco Majestouch TKL (blues) | Goldtouch V2 x 2 | Matias Ergo Pro x 2 | Kinesis Freestyle Pro (browns) | Kinesis Freestyle Edge (reds)
Offline Zamorph
Cherry reds?
« Reply #6 on: Thu, 08 December 2011, 21:17:01 »
leopold!!!!
Offline RPro
Cherry reds?
« Reply #7 on: Thu, 08 December 2011, 22:25:50 »
I have 2 of the Rosewills - the 2nd one has a very squeaky spacebar (can hear it outside of the office occasionally lol!) - I'll lube it one day, but reviewers on newegg have successfully RMA'd for such a thing. The USB connector leading into the keyboard is flimsy so be careful if you move it around too much - my 1st keyboard I had to hot glue the cable onto it as I was testing custom keyboard tray adjustments and I think I bumped it way too hard and the connector on the PCB side nearly came off haha!
Just don't abuse it like I did and the Rosewill should be fine. :)
Offline Gerk
Cherry reds?
« Reply #8 on: Thu, 08 December 2011, 22:30:38 »
Quote from: dante;466881
I would love to see Neweggs RMA reports on this keyboard as it pertains to ping.
It falls under their standard return policy.  30 Days replacement, or refund (with restocking fee).  They are very easy going about returns for most things.
http://www.newegg.ca/HelpInfo/ReturnPolicy.aspx#10044
Offline pitashen
Cherry reds?
« Reply #9 on: Fri, 09 December 2011, 00:54:31 »
If you are not much of a risk taker, Newegg's RMA service is hard to beat.
Offline drsauced
Cherry reds?
« Reply #10 on: Fri, 09 December 2011, 20:09:43 »
Ping!!!!
Offline patrickgeekhack
Cherry reds?
« Reply #11 on: Fri, 30 December 2011, 09:27:01 »
Question to those who have the RK-9000RE. My coworker bought one and when I compare it to my Filco with Cherry brown, I find the brown Cherries on my Filco to be lighter than the red Cherries on his Rosewill. Is it because one is linear and one is not?
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline iBro
Cherry reds?
« Reply #12 on: Fri, 30 December 2011, 12:50:44 »
If you don't mind the logo, go with the Rosewill.
Unicomp Space Saver (buckling spring) Silicon Graphics (dampened cream alps) KBC Poker (ghetto reds)
Offline Human
Cherry reds?
« Reply #13 on: Fri, 30 December 2011, 13:01:22 »
For some unknown reason, filco r is back to pchome for 184$ shipped.
But one thing I am pretty sure, it won't last long...
Offline aynjell
Cherry reds?
« Reply #14 on: Fri, 30 December 2011, 14:28:16 »
I got the rosewill, and it's my current gaming keyboard. my wasdkeyboard key set tranasferred over with no fuss and I used the keycaps that came iwth the rosewill (because they feel great) on my das keyboard silent which is not at work.
Offline WiL11o6
Cherry reds?
« Reply #15 on: Fri, 30 December 2011, 15:10:08 »
I went from Filco browns to blacks, and wanted Filco reds but they are not readily available so I went with the Rosewill with reds. I read that the Rosewill is pretty much a Filco in terms of quality and having all 3 boards together at the same time, I can say that is true. If it were a blind test, you probably wouldn't be able to tell the two apart, well other than the obvious Rosewill/Filco logo. The only thing that's different are the keycaps. I like the Filco keycaps more as they are smoother and you can't feel the actual letters on the keys. I can feel the letters on the Rosewill keycaps, and I prefer them to be smooth, but of course that's not a deal breaker as I can switch out keycaps.
The brown had a weird tactile feel that's like between linear and tactile and I didn't like that as it felt weird typing and gaming on it so I went with blacks thinking it would be perfect because I thought the browns were too light. I was wrong. While the blacks felt great for gaming, it was too heavy for typing and I got tired very fast. Went with the Rosewill reds and it's exactly like the blacks but much much lighter. Much more comfortable to type on and they feel about as light as the browns, if not lighter because there's no tactile bump, so you'd just end up bottom out pretty easily. I do prefer blacks for gaming because it just feels better when say, I'm playing Battlefield 3 and I'm moving my soldier around, each key press feels like I'm really controlling him. With the reds it's nicer because I don't get fatigue compared to the blacks, but there would be times when I would have my finger resting on the A, not knowingly, and I'd be running straight and then keep running left and I'm like, "why am I running sideways? Oh opps, my finger was on A the whole time."
But of course, it all comes down to preference. Most people love browns, I do not.
Offline tukkez
Cherry reds?
« Reply #16 on: Fri, 30 December 2011, 18:36:31 »
Can't find the filco R at pchome? LinK?
Offline RiGS
Cherry reds?
« Reply #17 on: Fri, 30 December 2011, 19:40:23 »
I really like the coating on the Filco keys.
Offline aynjell
Cherry reds?
« Reply #18 on: Fri, 30 December 2011, 20:06:50 »
Quote from: WiL11o6;480508
I love browns, I love reds, and I love blues. Different places, though. Blues for starcraft are sublime, as are browns. I haven't gotten a good read on the reds yet, but the keycaps that came with my rosewill are on my das keyboard browns at work and I LOVE these caps. They're awesome and an upgrade over stock das keyboard caps.
( i have a custom key cap set from wasdkeyboards tailored for sc2 use and I love it and definitely better for sc2 use than the stock caps )
Offline Reptile
Cherry reds?
« Reply #19 on: Fri, 30 December 2011, 20:12:58 »
Quote from: tukkez;480693
http://global.pchome.com.tw/DCAH1Z-A56476468
No TKL :-(
I can't tell if they had them again and sold out or just stocked the 104 ones again
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline DryDry
Cherry reds?
« Reply #20 on: Fri, 30 December 2011, 20:17:33 »
Quote from: RiGS;480732
the coating is so soft that easy to wear
I am not tall,not handsome,but a little bad……
Offline Hazborgufen
Cherry reds?
« Reply #21 on: Fri, 30 December 2011, 23:40:35 »
Quote from: Gerk;466890
I'm going to be using this. My first mechanical keyboard was a Rosewill with red switches that I got for Christmas. Well, the USB connection on the board broke. It is less than confidence inspiring to say the least.
Offline sordna
Cherry reds?
« Reply #22 on: Sat, 31 December 2011, 00:36:30 »
Me neither. For me it's: Reds > Blues == Blacks > Browns.
