Author Topic: hardwired dvorak keyboard?  (Read 8698 times)
Offline FinancialWar
« on: Sun, 11 December 2011, 20:38:39 »
so I got a new job however, this time I am not allowed to configure windows keyboard layout.
So is there a hardwired dvorak keyboard (mechanical, hopefully) on the market at the moment?
Please do not recommend kinesis.
Thanks.
« Reply #1 on: Sun, 11 December 2011, 21:08:14 »
thank for the reply, have you had any experience with the Qido convertor?
Offline sordna
« Reply #2 on: Sun, 11 December 2011, 21:16:09 »
Quote from: dvorak;468566
No Kinesis? How about Truly Ergonomic, they say it's programmable. It's shipping next week, so we'll know from reviews soon.
The Rapoo v7 might be a good option. It's programmable, according to this review:
http://deskthority.net/viewtopic.php?f=4&t=1153
Offline SmallFry
« Reply #3 on: Sun, 11 December 2011, 21:22:13 »
I'll be selling AIKON controllers soon, that would make any keyboard that you could imagine programmable...:biggrin: Hope you can find what you're looking for.
Offline Tony
« Reply #4 on: Sun, 11 December 2011, 21:25:38 »
Can you run .exe? Dvorak assistant will help you toggle between Dvorak and Qwerty
http://sourceforge.net/projects/dvassist/
Offline Playtrumpet
« Reply #5 on: Sun, 11 December 2011, 21:41:26 »
I'm just jealous that you have the username dvorak..
Dvorak
« Reply #6 on: Sun, 11 December 2011, 22:09:47 »
no, it has to be on the keyboard hardware level, no messing around with softwares on the pc or OS as the techs can be really jerks and I am only new in this job.
« Reply #7 on: Sun, 11 December 2011, 22:13:18 »
Quote from: sordna;468584
I might have to consider kinesis advantage, regarding to typing speed, how do you find this keyboard when compared to normal brown cherry keyboards?
and another important question, do you need OS to switch between qwerty and dvorak with the kinesis?
this listing on ebay says it requires the OS to switch between qwerty/dvorak, I was under the impression that qwerty/dvorak switch on the Kinesis advantage was on the hardware level.
« Last Edit: Sun, 11 December 2011, 22:25:14 by FinancialWar »
Offline Tony
« Reply #8 on: Sun, 11 December 2011, 22:51:33 »
Give the DvorakAssistant.exe for the IT guys to check it and he'll let you use it in your profile. Hopefully your line manager will help you.
Offline sordna
« Reply #9 on: Sun, 11 December 2011, 23:13:02 »
Quote from: dvorak;468614
Well, I would say the Kinesis will allow you to type faster because less hand movement is needed. I went from flat keyboards/qwerty to Kinesis/dvorak and the overall change for me was from 80wpm to 100wpm after a few months (till I got used to Dvorak, getting used to the Kinesis took me just 2-3 days).
Not at all. All programming, layout switching, etc, is done via keystrokes on the keyboard itself.
The ebay seller doesn't know what he's talking about. All Kinesis Advantage models are dvorak switchable on the keyboard itself.
Anyway, the Rapoo v7 is mechanical and prrogrammable and supposed to hold the settings in memory, so you can program it in your home, and take it to work.
Another option is this rubber dome keyboard from Fentek: http://www.fentek-ind.com/kbdvorak2ub.htm
Fentek by the way is a great place to for Kinesis keyboards, with free shipping, and they honor the Kinesis no-risk money back guarantee.
« Reply #10 on: Mon, 12 December 2011, 00:23:29 »
Quote from: dante;468582
No experience; but the company that produces it has a solid reputation.
I was considering buying one myself but the shipping charge makes me queasy.
I thought about doing a group buy but I don't know if I could even get 10 people to sign up for one.
It'd probably be just as easy (and a lot cheaper) to build one using a microcontroller.
If I were you, I'd talk to HR or the IT people about changing the keyboard layout in windows. I imagine the paranoid computer guys would balk at any .EXE a lot more than that. If that fails (and you do a lot of typing) you might be able to persuade them to get you a kinesis/maltron for ergonomic reasons. Failing THAT, I'd grab a new keyboard.
Me, I am not allowed to plug a new keyboard into the computer I use, nor change the layout or anything, so I'm out of luck.
Offline Tony
« Reply #11 on: Mon, 12 December 2011, 00:45:52 »
True, HR dept will talk sense to IT dept and your problem will be easily solved. From IT point of view, EXE file is much more risky than just reconfig the computer.
« Reply #12 on: Mon, 12 December 2011, 00:52:35 »
I'll probably just get the kinesis advantage, it has this cool factor and probably retain a lot more resell value.
Offline Apokalipse
« Reply #13 on: Mon, 12 December 2011, 10:35:15 »
Autohotkey script:
Code: [Select]
#UseHook
Process, Priority,, Realtime
SetKeyDelay -1
; scroll lock set to on when script is active
SetScrollLockState, On
Scrolllock::
    Suspend, Permit
    Suspend
    if (A_IsSuspended == true)
        SetScrollLockState, Off
    else
    return
; qwerty to dvorak
q::'
w::,
e::.
r::p
t::y
y::f
u::g
i::c
o::r
p::l
s::o
d::e
f::u
g::i
h::d
j::h
k::t
l::n
SC027::s
z::SC027
x::q
c::j
v::k
b::x
n::b
,::w
.::v
/::z
Offline Kurk
« Reply #14 on: Mon, 12 December 2011, 12:00:37 »
Native Dvorak keyboards should be available from Unicomp. Their SpaceSaver M (for Mac) for sure is so I guess the PC models will be, too. You'll have to call the and ask.
http://pckeyboards.stores.yahoo.net/onthestick.html
Offline sordna
« Reply #15 on: Mon, 12 December 2011, 16:55:03 »
Quote from: dvorak;468672
Good choice. There's a special model, the Advantage LF, with cherry MX red switches, but it's only available by request at Kinesis at $325. Click my sig for details. If you buy from a reseller, you'll only be able to ge the model with MX browns, but it will be cheaper. Another option is to buy it used... I think Input Nirvana may have some for sale, and they pop up on eBay now and again too.
Offline Kurk
« Reply #16 on: Tue, 13 December 2011, 05:08:11 »
...QUOTE]
Unicomp's SpaceSaver models can be ordered in Dvorak layout. These are actually hard-wired (I've asked). Maybe other models can be ordered in Dvorak, too.
Offline Kurk
« Reply #17 on: Tue, 13 December 2011, 11:23:50 »
Upon asking if one needed to change the keyboard layout in the OS for use with their Dvorak keyboards, Don Bowman from Unicomp mailed me that "Use of our Dvorak keyboard requires no key reassignment in the OS.  What you see is what you get, so to speak."
Note that this conversation was about the SpaceSaver M (for apple).
Offline ownerer
« Reply #18 on: Tue, 13 December 2011, 11:47:52 »
I use the QIDO at work and it rocks!
Offline Input Nirvana
« Reply #19 on: Tue, 13 December 2011, 11:50:15 »
Quote from: ownerer;469737
Anything else, or is it just that simple? (hopefully just that simple)
Pros/cons/thoughts?
Offline Ekaros
« Reply #20 on: Tue, 13 December 2011, 11:54:26 »
Tipro?
Anything with low-level programming should work.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
« Reply #21 on: Sun, 18 December 2011, 20:41:44 »
does anyone know where I can get the Kinesis Advantage in Australia? That eBay seller is now gone. I don't know where to get one of these in Australia for a reasonable price. All the Australian sellers are selling them for more than $AU600 which is a rip off.
« Last Edit: Sun, 18 December 2011, 20:44:02 by FinancialWar »
Offline sordna
« Reply #22 on: Sun, 18 December 2011, 21:52:14 »
Maybe you can contact Kinesis directly, possibly they can ship to Australia for a smaller overall cost. Another option to keep looking on ebay.com.au for a used one. I just did a search for completed listings, and saw a US seller sold one for $269 + $43 shipping which is less than half what your Australian sellers want to charge you:
http://www.ebay.com.au/itm/NEW-Kinesis-Advantage-Keyboard-QWERTY-Dvorak-/160382102062?pt=PCA_Mice_Trackballs&hash=item255784aa2e
So if Kinesis doesn't ship to Australia (dunno if they do or not) chances are some of their US resellers might. You can try fentek-ind.com, amazon.com, thehumansolution.com, and others.
« Reply #23 on: Mon, 19 December 2011, 01:10:05 »
thehumansolution sold out the kinesis and other US ebay sellers do not post to Australia.
My Dad is going to China in two days time, is there a retailer their?
Offline sordna
« Reply #24 on: Mon, 19 December 2011, 01:27:46 »
No idea about China, but nevermind ebay, did you go to the actual websites I mentioned? For example if you go to thehumansolution.com they have 3 different Kinesis Advantage models, and various international shipping options.
I just tried USPS Priority International and it quoted me $51.
« Reply #25 on: Mon, 19 December 2011, 08:28:24 »
Thanks sordna,
So I checked thehumansolution.com, I didn't know there were two types of kinesis advantage? One that has only Qwerty and the other version that have both Qwerty and Dvorak. Can you confirm the one with both layout is the KB500USB-QD-BLK so that I don't get the Qwerty only version.
Thanks.
Offline sordna
« Reply #26 on: Mon, 19 December 2011, 11:53:53 »
Quote from: dvorak;473689
Thanks sordna,
Thanks.
Yeah, the one with the QD in the part number has the dual printed qwerty/dvorak keycaps. Note that all Kinesis Advantage models support qwerty/dvorak switching, if you can touch-type dvorak you don't need the special keycaps. My first Kinesis (a PS/2 Classic) had the QD keycaps, but all my later ones don't, and I happily type Dvorak without missing the QD at all.
« Reply #27 on: Tue, 20 December 2011, 06:13:23 »
oh ok I get it.
So all Kinesis Advantage keyboard have qwerty/dvorak switching, only those with QD have qwerty/dvorak printed on keycaps.
yes, I do touch type (I don't think there are any dvorak users who don't), and in fact, I prefer blank keycaps, do you know if Kinesis Advantage come in blanks?
Black Kinesis Advantage in blank black keycaps would look awesome.
Offline sordna
« Reply #28 on: Tue, 20 December 2011, 10:57:26 »
There is no model that comes with blanks, although perhaps Kinesis directly may be able to provide you with a set, just contact them. Otherwise, you can always sand or dye your keycaps, or buy after market ones. These instructions will prove useful.
Offline Allagion
« Reply #29 on: Mon, 16 January 2012, 18:25:42 »
There is one issue, which is admittedly situational, in which a hardwired dvorak keyboard may be useful. I am in law school and most students take exams on Examsoft. Your system reboots into safe mode for the duration of the test and examsoft doesn't give a hoot what keyboard layout you prefer, you are going to type in QWERTY. There is no way to change your preferences after reboot either. Having a hardwired board, or at least the QIDO, should circumvent that issue. My professors don't care that I bring in an external keyboard to plug in to my laptop.
« Reply #30 on: Tue, 17 January 2012, 20:15:35 »
I tried and return kinesis, the layout and the built quality is not by thing. Plus it is too bulky. I got the QIDO, I am going to get the Rapoo V7 as well to solve my Dvorak issue outside home.
« Reply #31 on: Tue, 17 January 2012, 20:23:11 »
We lost a family member :(
Offline Reptile
« Reply #32 on: Tue, 17 January 2012, 21:22:41 »
Quote from: FinancialWar;468609
What kind of job is this? Doesn't make sense they should let you do it.
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline clickclack123
Re: hardwired dvorak keyboard?
« Reply #33 on: Wed, 18 December 2013, 03:02:45 »
Resurrecting this necro thread but:
the CODE keyboard at http://codekeyboards.com/, which is a rebadged WASD V2 has dip switches on the bottom that can switch it into dvorak layout.
