Author Topic: Das and WASD key caps  (Read 1473 times)
Offline Gin
« on: Tue, 13 December 2011, 02:42:55 »
I have a quick question:
A friend of mine has a das keyboard with stock key caps and he wants to get a set of WASD key caps from WASD's website to checker them.
Are the key profiles the same? How different are the textures?
Thanks,
Offline nikonf5
« Reply #1 on: Tue, 13 December 2011, 08:12:52 »
The key profiles [Rows labelled 1,1,2,3,4,4 from bottom to top] are the same and if you are mixing and matching Das and WASD, the height of the keycaps are also identical so you wont have any problems there either.
I had two Das's, one is now used by the gf and I sold the other one with its WASD keycaps on it so this comes from experience.
HTH
