Author Topic: Recommends for audio/video/media conversion software?  (Read 3372 times)
Offline Voixdelion
« on: Tue, 13 December 2011, 13:52:34 »
Need a definitive solution for format switching in audio and video files as I always seem to have something that isn't the right one for what I need to do with it. I'm totally over all the trying of various ones that are limited so I can't really get a good idea of it, or free ones that only do one format to many in only one direction. I am happy to go separate ways for a good solution if its one for audio and one for video, but I want bi-directional conversion capability with as many formats as possible - possibly even at the expense of "ease of use" since I'd rather figure out one complicated piece of software ONCE than have to figure out several different simpler ones for each type of transmogrification. Anybody got recs and specs? I'd like to keep the cost under $40 for each but I can be swayed if I don't have to think about it anymore afterwards...
Oh, and it kinda needs to run on a 3.2Ghz p4 machine so I don't have to buy a new computer to use it (that's with 4GB ram + HD3850 AGP, if it matters -AND NO SNICKERING!!)
« Last Edit: Tue, 13 December 2011, 13:56:19 by Voixdelion »
"The more you tolerate each other, the less enforcement will happen."-iMav
fossala
  •  Guest
« Reply #1 on: Tue, 13 December 2011, 13:54:46 »
I convert everything with either ffmpeg or mencoder.
Edit: Both are free (libre) software so will cost you nothing.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Tue, 13 December 2011, 14:52:45 »
If you need some sort of GUI go with MeGUI if your doing mass audio dbpoweramp
fossala
  •  Guest
« Reply #3 on: Tue, 13 December 2011, 14:59:50 »
Handbreak is supposed to be good if you need a gui. (Once again it is free (libre) software)
« Reply #4 on: Tue, 13 December 2011, 15:00:54 »
Quote from: fossala;469926
Handbreak is limited compared to MeGUI and "transcodes" more than encodes.
fossala
  •  Guest
« Reply #5 on: Tue, 13 December 2011, 15:04:03 »
I haven't ever used MeGUI (I don't use a proprietary os). It seems to be written in .net, I wonder if I could get it to work with mono.
« Reply #6 on: Tue, 13 December 2011, 15:06:28 »
Quote from: fossala;469930
mono? as in mono audio? if you cant just use eac3to CLI which is what I recommended if you dont need a GUI fior audio thats going to be combined with video.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #7 on: Tue, 13 December 2011, 15:07:55 »
Mono as in the unix port of .NET
Filco w/ Imsto thick PBT
fossala
  •  Guest
« Reply #8 on: Tue, 13 December 2011, 15:09:59 »
It is not a port. It is entirely new code.
« Reply #9 on: Tue, 13 December 2011, 15:12:55 »
Just so you know MeGUI is written in .net but its just a gui it uses other programs to do everything so I doint know how compatible it would be.
fossala
  •  Guest
« Reply #10 on: Tue, 13 December 2011, 15:19:40 »
Yeah, looked into it. It is not going to work. Mencoder and ffmpeg are more than good enough anyway.
Offline Malphas
« Reply #11 on: Tue, 13 December 2011, 16:10:08 »
I use Avisynth and Virtualdub.
« Reply #12 on: Tue, 13 December 2011, 16:13:30 »
Quote from: Malphas;469987
MeGUI is a GUI to many things including Avisynth. My preferred GUI for Avisynth is AVSPmod.
Offline Malphas
« Reply #13 on: Wed, 14 December 2011, 13:29:26 »
Yeah, I know Virtualdub is very old school now, but I'm familiar with it and it works fine for what I need.  I tried MeGUI before, but it must have been in its infancy, because I thought was just a basic encoder frontend.  I never heard of AVSPmod before, I might give it a whirl sometime.
Offline nar
« Reply #14 on: Thu, 15 December 2011, 11:25:25 »
If your just converting video and audio formats (transcoding), I find MediaCoder to be very good and easy to use for that purpose.
Has a ton of different input and output formats, not as many features otherwise though compared to others.
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
« Reply #15 on: Thu, 15 December 2011, 12:36:47 »
I just want to make sure that everyone understands that for the most part transcoding is the least ideal.
Offline Malphas
« Reply #16 on: Fri, 16 December 2011, 14:39:25 »
Yes, TheProfosist is right, MeGUI is probably your best bet.  I thought this thread was about editing video for some reason, not just changing formats when I said this...
Quote from: Malphas;470694
That's actually ideal for the OP's requirements.
