Author Topic: Filco Ninja Keycaps  (Read 5055 times)
Offline USAgent
Filco Ninja Keycaps
« on: Thu, 15 December 2011, 10:08:16 »
Does anyone know if you can order the Filco Ninja Cherry MX keycaps, specifically WASD and ESC keys in red? I like how they have the text below the actual key. I'm looking on WASD Keyboards, maybe I'm just not sure the wording of how the keys are labeled?
Filco MJ2 Ninja 104 |  Ducky Disco TKL
Offline IvanIvanovich
  • Mr. Silk Underwear
Filco Ninja Keycaps
« Reply #1 on: Thu, 15 December 2011, 13:18:13 »
I'm pretty sure WASD doesn't do side printed keys. You would need to buy a KBC 37, 87, or 104 set side printed. See imsto or qtan on this forum, as one of them is likely to be able to get a set in red for you.
Offline USAgent
Filco Ninja Keycaps
« Reply #2 on: Thu, 15 December 2011, 13:23:54 »
Thanks for the heads up, I'll find out. Hopefully I can get just those 5 keys.
Offline emptythecache
  • out.
Filco Ninja Keycaps
« Reply #3 on: Thu, 15 December 2011, 22:46:06 »
Quote from: lysol;471506
I actually asked them this today, they don't. I wish they did.
