Author Topic: Looking for a keyboard  (Read 1772 times)
Offline Jgke
« on: Fri, 16 December 2011, 13:13:40 »
So I am looking for a mechanical keyboard.
I would like to have red backlit one, so that it would fit nicely to my desk (case has red lights). As for the switch type, I am moving more and more from playing to typing, so I would like to have either brown or blue switches. NKRO would also be a good thing to have, since I have played every now and then splitscreen, and I wouldn't like to hit the limit. I do not need macro buttons.
Also, since I am from Finland, I would like to have scandinavian layout for the keyboard. That's the main problem on my search, almost everything I've found has only american layout.
Offline Jgke
« Reply #1 on: Fri, 16 December 2011, 13:34:53 »
Looked through, didn't find what I was looking for. If there aren't any choices for me, I guess I'll have to drop the backlit and get something without it.
E: Oh, QPAD is Swedish and ships internationally. There's my find.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 16 December 2011, 20:57:39 »
Noppoo Pro. Out of stock, but you can ask them when / if it will be available again.
Offline digichaos
« Reply #3 on: Sun, 18 December 2011, 19:42:04 »
Corsair K60 or K90.
